Question about Cell Phones
I normaly charge my T-mobile (htc) phone when it has finished it's battery fully and i charge it fully. So once, when it was fully charged i tried to turn it on but it doesn't. PLEASE HLEP ME!! IT IS MY ONLY WAY I CONTACT MY FAMILY. THANK YOU!!!!!!!
    Guru:
  • 277 Answers
Remove the battery and see whether there is some difference in the thickness of the battery because battery contains dry cells which tend to expand due to over charge they recieve. If yes then the battery cannot sit on its terminals with the mobile. If so then you have to buy new battery, dont charge the baterry for much time in future. May be 1 hour is enough
Posted on Sep 07, 2010
How to swich on my HTC WINDOWS PHONE 8S ?
Are you 100% sure that its fully charged? Maybe a faulty battery or terminal. Batteries do fail after a time. Does it boot while plugged in?
Oct 06, 2016 | HTC Windows Phone 8S
Why won't my Pride Go-Go Elite Traveller batteries charge using a trickle charger? The batteries are new, but my charger quit working.
Hi Robert , can you clarify what you mean by a trickle charger ?, any chance of a photo of the charger ?
using a standard gel battery charger , the charger will charge the batteries in question and once fully charged, the charger will trickle charge the batteries.. This is a standard operation and recommended by battery makers...
Regards
Rob
Jan 09, 2016 | Pride Health & Beauty
My htc one mini isn't turning on, But it comes up with the battery sign? What's wrong with the phone?
It sounds like you need to charge it up.the charge icon usually means there is insuffient power to switch on.it may be the battery isn't charging properly I.e. The charger is faulty...the charging point is faulty...or the battery is no longer holding a charge.sometimes if you charge abroad or on say a ship where the amp of the circuit is less the 500 mah the charging behavior changes and it takes a few attempts to get it to behave normally.
another thing you might try is change the charger to a more powerful one just to give it a boost.i.e. Instead of using the normal 5 volt 1amp try a charger with 5volt 2 amps.once the battery reaches at least 5%. It should start up.fully charge and then try to get into the habit of running phone down to 20% and up to 80. % instead of continuously charging each day when the phone is still holding a healthy percentage?only once in while should you run below 5% and then charge to 100% .incidentally most batteries start to lose their stamina after 500 plus charges.
Feb 05, 2015 | HTC Cell Phones
Am charging my mobile but when i keep it in the mobile it is showing that the battery is low or empty
Many cell phone used for a long time will met this kind of problems, it seems full charged, but once you are calling someone, the battery power will show empty.
1, mobile phone motherboard leakage lead the current too large.
2, the battery itself is aging.
Try to find out the problems and maybe an external battery can help you a lot
Apr 03, 2013 | HTC Touch P3452 Smartphone
My HTC mobile phone drains its battery too fast. I have to charge it every hour. This phone is brand new - only five days old.
turn the phone on and let it charge completelty. Then go and shut the phone off. Reboot the phone in CMV which is dos for phones. (you can do this bypushing a combination of buttons usually power, volume down and home check to see what yours is) go through the menus and look for Wipe Battery stats. IF YOU DO NOT SEE IT go back to the main menu and reboot phone. Wait for phone to fully charge again and shut it off. Now while it is off keep plugging the phone in till it says it is fully charged. Then unplug the phone wait ten-15 seconds and plug back in until it reads 100% when you plug your charger in
Apr 19, 2012 | HTC Cell Phones
HTC Wildfire Battery is not charging fully
i am using an htc wildfire and it is not getting fully charged and when it reaches 30% the battery discharges even when the charger is connected. need help urgent
Jan 05, 2012 | HTC Wildfire Cell Phone
Dear, Sir i have htc desire mobile .it,s have
Check the voltage at the output of the charger unit, check the voltage at the pin. Now remove the battery and check the voltage, check the charge voltage at the pins of the battery terminal in the phone. If there is no voltage then there is fault in the mother board.
If the battery does not charge then the battery is a suspect , allow it to drain fully and then try charging once again before you can try for warranty claim if the phone is new.
Jul 07, 2011 | HTC Inspire 4G Smartphone
I need to install window mobile in my htc4350,how
download the firmware from htc.com
-select your model and check for upgrade
-download the upgrade
-connect your htc phone once done with the download.
-make sure that your phone is detected by computer
-double click on the downloaded file and follow the steps.(make sure that the phone battery is charged 50% up.
wait until the installation finishes and click the finish button.
disconnect phone and set it up.
Jul 28, 2010 | HTC Touch P3450 Smartphone
Htc touch diamond freezes on start-up
I called and spoke to HTC ..apaprently there are issues with some of the handsets .. and its power related ... the best this is to do 2 things to solve any number of issues....
A: Get a replacment battery, and recharge it fully without turning the phone on. So plug it in and charge it until the white pulsating light is fully lit and not 'breathing' ..as they say. Once fully charged then turn on your phone...
B: Once on ... 'hardware' reset it -  (you turn on the phone, holding the volume down button, and the hang up button and pressing the 'software reset button, at the same time)
Should solve it ... IF it dosent .. and your getting the same issues after battery replacment, software and hardware resets ...you've basically got a 'hardware' issue with the phone in which case you need a replacment or repair... (make sure your phone is insured)
Hope that helps folks...
p.s. My phone eventually stopped charging ...nothing, no power so i sent it back for a replacment which im waiting for to arrive...
Nov 17, 2008 | HTC Touch Diamond Smartphone
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
