Question about LG enV VX9900 Cellular Phone
When my phone is open the speaker phone works but when i close it i cant get the earpiece volume to work?
  • 4 Answers
Sounds like a connection problem. Something is probably lose on the circuit board. Did you damage it any known way?
Posted on Sep 08, 2010
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
No volume on incoming or outgoing calls unless using the loud speaker
the problem of your phone is in the earpiece.... try to open or dismantle your phone if you know how to dismantle... get a tester to check if your earpiece is still working.. and if not, u need to replace your earpiece... but if still working, try to clean the earpiece terminal maybe it is just corroded or dirty... goodluck my friend....
Feb 27, 2011 | Cell Phones
Can hear caller on speaker on but not on headset. when someone calls and i answer i cannot hear them on the headset only on speaker. voice volume is all the way up.
The headset speaker is faulty, the earpiece.
So open the phone and make a audio test on the earpiece , If the sensitivity is low the earpiece speaker is faulty.
replace or try with a salvaged on frrom an old phone. Now you are confirmed. If not there can be issues in the board, the preamplifier.
Sep 20, 2010 | AT&T LG CU515 Cell Phone - Black
My daughter has an lg 5300 phone - she can call but can't receive or hear the person she is calling..
The reason she can call out and the person she is calling can hear her is because the mouth piece is working perfectly.
The reason she can't receive a call or hear the person she is calling is simply because the speaker of the phone is faulty.
  1. remove the battery cover, the battery and the sim,
  2. Use the screwdriver or tweezers to gently pry off the RF grommet located on the antenna cap,
  3. then you can split the phone open carefully and try to locate the speaker
  4. by lifting up the panel below the speaker,
  5. carefully disconnect the speaker from the board,
  6. and replace it with a new one,
  7. reverse the whole procedure for reassembly
take care
Jun 18, 2010 | Cell Phones
I can't hear the person talking on the phone earpiece. The volume is on high and the speaker phone works fine?
Sir/Maam,
It can be that the earpiece is broken. Try calling someone without using any earpiece, if that works that proves the earpiece is damaged or broken.
If that doesn't work, then the speaker in your phone must be damaged.
Hope i helped you, thanks.
Feb 27, 2010 | Cell Phones
I lost the volume in my earpiece on my LG EnV3... I can't hear anyone but they can hear me.. I have to open it and speak on the speaker phone.. is there a setting that I can change to turn in back on?
I just started having this same problem end of last week. It would work after I started the conversation, to close the phone again, but now that doesn't work either:( Someone please help!!
Feb 11, 2010 | LG enV3 VX9200 Cell Phone
Cannot hear
In this case check the volume of you're Handheld, If it is low, Increase the volume and check still if it is not working you need to walk into the service center to check the speaker of you're Handheld.
Oct 21, 2009 | RIM BlackBerry 8700c Cellular Phone
Cant hear incoming voices unless i put it on speaker. Can hear rings and all phone bells and whistles though. just not earpiece volume for incoming calls unless on speaker
this sounds like a broken earpiece speaker you might be able to find a replacement one on-line and replace it or if its still under warranty send it back in and get it replaced
Sep 25, 2009 | Motorola Mobility RAZR V3
LG enV VX9900 Cellular Phone Logo
129 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
