I have a SONY KV-29 X5D standard (CRT) TV set, who lately started presenting the following symptom: As soon as I switch it on, the red led is blinking, the audio comes normally out, but the screen is completely black. When I shake or hit the set slightly, the picture appears normally. Also, if I keep the set at a certain angle (usually with the CRT facing slightly towards the floor, the picture is there also!.... But if I leave the set to rest at its normal position, the picture goes off again!... I am an Electrical Engineer, but without any involvement and experience on CRTs, so I can't figure out where to focus in order to deal with this failure.... Could somebody help please? Thanks, Thomas
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
Hi Thomas, being an electrical engineer, why don't you understand the fault is due to some loose contact inside the RV? Very shame indeed. Look for that.
google.com/+GopakumarGopalan
Posted on Mar 27, 2017
  • 163 Answers
SOURCE: TV image goes black, red light keeps flashing - hitting sometimes helps recover
you most have a cold solder but wachtout dont foolaround with tv sets they are very dangerous to a person that have no experiences with it and you could produce a larger damage..good luck...
Posted on Jul 24, 2006
  • 556 Answers
SOURCE: sony wega 27'' crt hdtv issue DZ-29m61
object in the picture look small,tiny and elongated especially when viewed from certain angles.Worse,the picture seems to have a horinzontal bend towards the bottom of the tv screen it is due to malfunctioning due to technical defects in TV. YES the problem is in vertical output section of your TV. IT is due to some electrolytic capacitor failure in tv. if it is replaced by the same value as it is your problem will be solved. hope this will help. good luck. it is a common problem & not major.
Posted on Oct 08, 2007
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
SOURCE: TV will not turn on/black screen/picture/green LED is red/blinkin
I had the same problem for my TV which was model number: 42PF9631D/37 and I went to get the software update at http://www.p4c.philips.com. Type in your model number, then click on the right model. Then click on software & drivers in the left column. Then download the correct software update to a flash drive. The flash drive must be completely empty except for this file. Then unplug your TV, and plug the flash drive into the USB port. Plug your tv back in, and the software update will upload. It fixed my TV instantly.
Posted on Jan 09, 2009
  • 56 Answers
SOURCE: 29"Colour TV ,Sound Normal ,No Picture a vertical line Appears
Fault in HZ Deflection Stage check yoke also
Posted on Aug 16, 2009
Sony CRT TV not switching on power on LED keeps blinking
How many times do this standby LED blinks at one time switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty section circuit inside. Count it. If you wish to get more details, check this site. Pull up older posts there. Check this site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. Blinking codes to Sony CRT based TVs and all other models are given in detail. Check it and confirm.
Apr 08, 2013 | Sony FD Trinitron WEGA KV-29LS35 29" TV
I have sony 29'' crt tv . model no KV-DZM61 .when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 2 times .then the tv goes in stand by mode
2 blinks means - over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
Jun 23, 2011 | Sony KV-XR29M61 TV
I have a sony 29'' crt tv . model no kv 29xr m80.when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 8 times .then the tv goes in stand by mode .which section...
Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Mar 28, 2011 | Sony KV-XR29M61 TV
Tv is not getting on. one red led is blinking
Since you are having the red light blinking the power supply board is working fine and the set is tripped off due to some overload in the HT side. So after disconection of the power use a multimeter to probe. check for short in the HT side, the Line output transformer, the output drive. If there is no short and on powering the amin +B powerr drops off then if is possible failure of the LOT. You may notice that the output driver heats up before shutting. Confirm it before replacing with the original or take a consensus by asking an experienced friend to confirm.Any other short in the main board can also result in the same symptom. Hope you try . Good day
Aug 10, 2010 | Sony KV-XG29M61 29" TV
Sony Trinitron WEGA KV-XJ29M50 29" TV - Dead, LED flashes 2 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 24, 2010 | Sony KV-XJ29M50 29" TV
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
Sony tv kv-xj29m80 need to know what error code 2 means
IN THIS SONY TV KV- XJ29M80, IM FACING A PROBLEM THAT SET GOES TO ERROR MODE WITHIN FEW SEC'S AFTER GETTING IT ON, AND THE LED INDICATES 2 BLINKS AND GAP AND AGAIN 2 BLINKS AND CONTINUES..PLZ HELP ME ...I WAS FOUND THE HORIZONTAL OUTPUT TRANSISTOR BLOWN AND THE 1.2 OHM RESISTANCE ALSO FOUND BLOWN...I REPLACED THE BOTH BUT THE PROBLEM IS CONTINUE...
Feb 19, 2009 | Sony KV-29LS60 29" TV
Tv, takes 30 minutes to open after switch on
resolder all cracked solders on the jungle ic.do you have any experience in electronics?
Aug 13, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
