Question about Kenwood KTS-300MR CD Receiver
I have a kenwood kts 300mr on a boat, the unit will not power up I've all the fuses and have power to the unit still power will not come on when the button is pushed
KaeZoo
  • 156 Answers
SOURCE: No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Posted on Mar 16, 2007
  • 3 Answers
SOURCE: Clarion M5675 won't turn on
Take the stereo all the way out and hook the black wire to the negative terminal and the yellow and the red wire to the positive terminal on a charged car battey. If it still does not turn on you may have fuse in the back of the deck. If not it's probably fried.
Posted on Apr 19, 2009
sonicboomele
  • 1557 Answers
SOURCE: Kenwood KTS-300MR
you need to firstly trace the speaker wires to the unit to make sure there connected first. if they are then its a job for a car audio expert ( if there is such a thing) if the unit is connected to correctly to the speakers then there is an internal fault ..
Posted on Jul 03, 2010
SOURCE: Kenwood kdc-225mr car/marine stereo will no longer
Need to get a new steering wheel wireless to communicate with the existing Kenwood KDC-225MR.
Posted on Dec 24, 2010
  • 30 Answers
SOURCE: I have a Kenwood KDC-MP2032
Try to check first the fuse on the fuse box of your boat if it is still good then the fuse of your stereo is located at the back of the stereo itself. Detached the stereo from its housing or holder you will see the fuse at the back of it.
Posted on Jun 29, 2011
Kenwood no sound
If you have a separate 'power' or sub-woofer amp, check that it still has power and did not blow a fuse. Is there an internal selection inside the unit for enabling the internal amp vs an external amp? Some will disable the internal amp using a setup setting, and just provide low level output that is expected to be amplified by an external amp. If it 'forgot' you might have to set it to use the internal amp again. Or vice-versa, depending.
Jul 23, 2014 | Kenwood KDC-S2009
I have a Kenwood KDC-MP2032 installed in a boat. I changed the battery in the boat and now I can't get the tuner to power on. If I need to replace a fuse, where are they and what size fuse do I...
Jun 28, 2011 | Kenwood KDC-MP2032 CD Player
I have 4 wires, red (power(, black (ground), green (speaker), gray speaker...the stereo has these same color wires...so I connect the corresponding color. The boat has NO yellow battery wire that is on the...
(http://inform3.kenwoodusa.com/manuals%5CKTSMP400MR.pdf )
Here's a link to manual and wiring on page 30 on the PDF file.
Yellow is constant power from battery, for memory etc. Red should be to switched source.If need be, you can connect both to battery, but remember, you'll have constant power draw on battery when stereo left on but switch turned off, and will draw battery down, if you forget to shut it off, and leave the boat. Speaker negatives to black should work but I would advise hooking my 2 right and 2 left + speaker wires from stereo together, then to one of the speaker positives,right or left for better sound. Fronts will usually supply higher ( high and mid range), and rears will supply lower sounds (woofer) Joining them together will give better sound usually, when only using 2 speakers, on a 4 speaker stereo. You may want to test with them joined and not, to see what sound you like better.
Sep 26, 2010 | Kenwood KTS-300MR CD Receiver
Kenwood KTS-300MR
Jul 03, 2010 | Kenwood KTS-300MR CD Receiver
I wired additional speakers to my Kenwood car radio/cd player, that is in my boat. When I turned it on it played really loud and I could not turn it down. I turned it off and now it will not turn on. I...
When you connect multiple speakers to one channel it drops the impedance. A radio is designed to play at 4 ohms which would generally be one speaker. When you connect two speakers to one channel it drops to a 2 ohm load which can be fatal for a radio but not always
Jun 05, 2010 | Kenwood KTS-300MR CD Receiver
CALL on display
Hello plainolelow,
"CALL" is displayed whenever a telephone call is received.
This is controlled by the brown wire from the wiring harness, and is activated when your telephone system or bluetooth device adapter detects an incoming ring. Activation is a "ground" on the lead. If you do not have a telephone or bluetooth adapter attached, the wire is probably coming into contact with some other wire or metal that is causing it to be momentarily grounded.
Hope this helps.
Jul 17, 2009 | Kenwood KTS-300MR CD Receiver
The AUX stopped working. I can get CD and Tuner
I don't have a solution, but did you ever get this working again? I'm having the same issue. Thanks
Jul 12, 2009 | Kenwood KTS-300MR CD Receiver
Volume buttons
the tact switches have failed to the vol up and down switches. This is common as they do the most work. replacing the switches will fix it
Dec 28, 2007 | Kenwood KTS-300MR CD Receiver
Mar 16, 2007 | iLO XM-MP3-CD Car Stereo
Kenwood KTS-300MR CD Receiver Logo
80 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
