Question about KitchenAid KSSC48QMS Side by Side Refrigerator
Sometimes there is leakage from the bottom, I think coming from the freezer side
  • KitchenAid Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 12, 2010
GE Profile side by side refrigerator. The freezer side started to have leakage and caused frozen ice along the walls & Extreme suction on freezer side.
Not sure on this one, but many freezers draw a vacuum like that for a little while to try to get all of the air and moisture out. Commercial units are designed that way. If Ice is building up, there is most likely an air leak. Check the door gaskets and see if they are sealing up properly.
Aug 02, 2016 | GE Refrigerators
I have a whirlpool side by side refrigerator with freezer on the bottom. It is leaking. How can I fix it?
Check back of bottom refrigerator there is drain water line I think there is leakages . check and fix it
Jul 23, 2016 | Whirlpool Refrigerators
I have a water leakage coming out the bottom of my kenmore refrigerator model 52559100
check your defrost drain line. can be located in freezer section. also if you have a filter at the bottom make sure the housing is not cracked. If your frig is cooling then the coil is going to be doings its job
Jun 08, 2012 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water leaking onto floor coming from under refrigerator
Their are a couple things causing that leak
1) the water valve(s) for the icemaker/door dispenser are leaking. Pull the refrif. out,remove service panel from the rear and inspect the valve(s) for leakage. Sometimes their is just one valve on certain models their is two.
2) the drain for the auto. defrost cycle in the bottom of the freezer back wall is blocked so the defrost water is running out of the freezer door at the bottom
Good luck,i hope i have able to help you stop the leak,
Aug 20, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
Our gladiator bottom freezer/refrigerator stopped working while we were on vacation last week. The motor still runs, but the air blowing out is not cold. We cleaned it out, unplugged it and plugged it in...
It is possible that your compressor has redduced in pumping or the gas pressure has redduced, ;leakage of gas. Sicne you had put off the fridge for sometime and tried again without any result, I think the compressor needs a good check. Since the fridge has to cool definately when the motor runs we must start from here . I hope you check this out or maybe get help to confirm definetely with an estimate. Good day.
Aug 02, 2010 | Gladiator GAFZ21XXMK Bottom Freezer...
Im thinking of buying the MFF225VE bottom freezer but am wondering can you remove the freezer baskets to clean the bottom floor of freezer?
The baskets do come out, there are some tabs that can be depressed on each side and the bins come up. If you want to take the entire drawer out you would need to remove a couple of screws from each side to accomplish this.
Let me know if this was helpful or if you have questions.
Thanks
Jun 14, 2010 | Maytag MFF2258VE Top Freezer Side by Side...
Water leakage from the door
your freezer cabinet need to get all out and open the back wall
there is a drain hole in the bottom middle of it make sure it is
clean and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday . com
Jul 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaking at bottom of freezer side
that is not a leakage it might be sweating of the chilled line. and to collect this water there will be a tray fixed below the freeser or refrigerator exactly on the condensor so check this tray is in its place.
May 28, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
KitchenAid KSSC48QMS Side by Side Refrigerator Logo
65 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
