Question about Vacuums
Where can i find spare parts for a hinari hsp240 steam press namely the bearing roller unit on the handle unit
  • Vacuums Master
  • 3,083 Answers
Here's the problem with Hinari- they don't have a support site, or parts department on the net. Refer to your literature that came with it, and contact them to find out how you can get a replacement roller unit. Obviously, however, they don't make it convenient to contact them, so I'm not positive they will help, but hope so.
A lot of companies sell a lot of things as "throwaways" and have been doing it for years. Sometimes, you can find a used one somewhere, and rebuild your broken unit. I searched on Ebay, but didn't find anything.
If the bearings aren't sealed, you might be able to regrease them, but this may not be an option.
Wish I had better news, but good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 07, 2010
My Bissell 61c5-g started making a loud noise, vibrates bad, what can I check? I adjusted the height and it isn't connected there.
Most likely a bad belt. Contact Consumer Care at 1-800-237-7691 to order parts (detailed instructions comes in the package. To open the Belt area access panel you will need a flat medium sized screwdriver. There are two slots on the right hand side of the unit. Push the screwdriver into the lower slot and press the holding tab to lift the panel. The top tab should slide out easier but if it doesn't use the same process as the lower one. Examine the belts by rotating them all the way around (there may be two belts in your unit). I'd recommend if one belt is bad to replace both belts and keep the used one as a spare. Good luck. Hope that helped.
Oct 30, 2015 | Bissell Vacuums
Easy steam express ll not steaming
The problem with the DD steam mop is not getting steam out but trying to get it to keep coming out. If U disassemble the plastic housing around the handle U will see a small part connected to 2 hoses, one going to the water reservoir the other going to the heating unit. This is the pump which provides water to the heating unit, and if this fails U won't get steam. U can try disassembling this and try to get the piston to move more freely. A loud clicking sound coming from this should indicate good movement and a feeble click click click may indicate restricted movement.
Hope this helps
Apr 28, 2012 | Dirt Devil CE7000 Easy Steamer Upright...
We need a spare attachment for a hinari vacuum cleaner
Check the service section in your manual.
You will get any Hinari manual with the manualfox search engine. Check results here:
http://manualfox.com/link/hinari.htm
May 10, 2010 | Numatic HHR-200 Henry Hound Bagged...
I broke the handle part of the shark steamer #53101. I don't have the book to try to tell you the parts I need. Can you send me a picture or a copy of the steamer. It is purple. The above number may not be...
Ann there are very few parts for these...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Sep 24, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Bissell 8920 won't release fluids at the rollers
I have an 8920 ProHeat 2x as well with the same issue - no spray at the rollers. Seeing that the hand tool worked I checked the finger switch for continuity and it was good. Turns out the red spray heads that clip into the unit just under the water tanks were the culprit. I popped those off and ran a paper-clip through them from the front. I must have contaminated the fresh water tank while emptying the grey tank. Works better than ever now, just thought I'd share what my issue turned out to be.
Oct 10, 2008 | Bissell 8910 ProHeat Clear View Upright...
DIRT DEVIL MADEL 08245 BRUSE DOSEN'T ROTATE
I had the same problem and fixed it to where it would work OK, althought not 100%. 1. Disconnect the hose that goes to the roller brush area. 2. Press the button right below the power switch while sliding the handle what ever direction it will go to release it from the body of the vac. 3. Remove 3 screws from the handle halves. 4. Remove 2 screws from a keyed black plastic piece that hold the handle halves together. 5. Carefully separate the handles halves from the clear plastic piece in the center that allows you to view the brush and belt. 6. If the belt is broken or missing, replace it and reassemble, if the belt is OK, remove the roller and test if the bearings spin freely. 7. If they don't, then remove the clip or clips of each end that hold the bearing(s) in place. (Work in a controlled environment so that when the little clip goes flying you'll be able to locate it without moving the refridgerator.) 8. Clean the back side of the bearing of hair, dust and dirt. (used compressed air if you have it) 9. Reassemble the bearing(s) you removed and cleaned on each end of the roller. I used a spritz of teflon dry lube spray on each when I put them back together. 10. Disassemble the air motor bearing from the shaft on the end that does not have the belt gear. Be careful not to lose the flat thrust bearing/washer at the bottom of the bearing housing. Clean, lube and reassemble. 11. Since I felt I couldn't remove the belt gear from the shaft (to get at the bearing), without damaging it, I worked at cutting the hairs and threads wound around the shaft. I used a single edge razor blade to painstakingly cut and remove what I could, then lubed and reassembled air motor. 12. I then reassembled everything and tried it. IT WORKED. The still sluggish bearing on the gear end of the air motor wasn't enough to stop the motor from turning the brush at an acceptable speed and torque.
Apr 30, 2008 | Vacuums
Cant find out where i get a new gun handle mine has snapped
http://www.spares2you.co.uk/Vacuum+cleaner+spares/Polti+steam+cleaners/Vaporetto+2400/
Mar 14, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
I need a "Bearing Assembly" for roller brush 61445-1,I Have a GE 106575
Probably should just go to a repair shop and they should be able to order one for you, that is if they are available by themselfs. Or if you have a store where you live that sells vacuum parts, you could go there.
Dec 08, 2007 | GE 106585 Upright Vacuum
No steam coming out
The fall might have damaged or moved the trigger so that it does not depress the valve on boiler.
Try removing the screws which hold the handle together. The cap needs to be removed to allow the handle to separate.
Once the handle is apart check the trigger piece looking for any broken parts.
Jul 07, 2007 | Euro-Pro Shark SC-505 Handheld Steam...
Vacuums Logo
95 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
