Question about Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit
My dc adapter is not staying connected properly. Can I fix it or get a replacement? I am having trouble finding the right one, 5V 200mmA.
  • artvalder Sep 08, 2010
    Thanks for the response! I have the original so I believe it's the correct one. I have taken it apart many times to no avail. I found a new one on ebay after checking with just about everyone else. Thanks!
  • Pioneer Expert
  • 509 Answers
First, double check the voltage on your adapter; XM uses BOTH 5Volt AND 6Volt adapters, and you need the correct one.
Second, sometimes the little plastic end of the DC adapter will come off and get stuck like a horseshoe over the little center pin. You will need a needle to remove this little plastic circle. Once the broken-off plastic disc is removed, your adatper will work much much better. See if that's the case and let me know.
Regards!
Posted on Sep 08, 2010
Testimonial: "Thanks!"
I know I need a 5 volt dc power adapter but I don't know the size of the end piece that connects to the speaker can you help me thank you.
Jean, take the speaker with you to the source or electronics shop and they will match you up with proper universal adapter.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
power adapters
Amazon com Universal 5V 1 2A AC Power Supply Electronics
5V Power Adapter eBay
http://www.walmart.com/c/kp/universal-ac-dc-adapters
Feb 27, 2016 | Audio Players & Recorders
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
Prolink h5201
No. You must use a 5V ac adapter/power supply.
But are you certain that you need 5V ac to power your modem ? Where are you located Jane ?
22.April.2014
Feb 16, 2014 | Computers & Internet
AC Power Adaptor LED won't stay on to power PC
First you you should test the AC power adaptor properly, then if it is in good conditions is important to test the electric circuit in the motherboard in order to find any trouble. There is a SMD fuse between de DC power jack and the rest of the circuit.
Jan 06, 2014 | Computers & Internet
I need a n ew DC power jack for my pandigital
Most of the Pandigital tablets use the power adapter APR001 which provides 5V at 2A. This is available from Geeks.com here: http://www.geeks.com/details.asp?invtid=APR001 . Other vendors may also have the adapter.
If you need to replace the jack where the adapter connects, try Radio Shack or http://www.mcmelectronics.com . You need to measure the existing jack dimensions carefully. (This ensures that the adapter will connect properly.) When you desolder the old jack and solder in the new one, make sure that you keep the polarity the same. (Otherwise the adapter may not work.)
I hope this helps.
Jan 22, 2013 | PANDIGITAL 7 Android with 2GB Internal...
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
I need to find a source for D-Link Part Number JTA3020A 5V-2A
almost all d-link routers use the same power adapter. All that's important is that it is 5v DC output, and at least 2.0A output current. So you should be able to pull an adapter from another router.
you don't actually need a REAL d-link adapter either, any adapter that matches those specs and fits the plug will work. Just beware, if you plug one in that doesn't match, you'll damage the device. I"ve found adapters like these at the local thrift store all the time.
Dec 04, 2008 | Computers & Internet
I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted...
i have the same probleme . I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted to know which is the correct product to buy please
Sep 08, 2008 | Iomega (33090) 250 GB Hard Drive
Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit Logo
89 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
