Question about Miele Dishwashers
I need to replace the Aqua Stop unit on my Miele G660 Premier dishwasher vintage 1995. How do I get at the dishwasher end of the plumbing/electrics please
2 Suggested Answers
  • 3 Answers
SOURCE: Dishwasher doesn't fill
try looking at the regultor it might be blocked theres a finn tube check it as it could be bunged up with muck
Posted on Mar 02, 2008
G660
GO TO http://www.miele.com.au/au/domestic/service/aftersales_spareparts_13796.htm
Jan 09, 2012 | Miele Dishwashers
G660 door falls open
Hi.
The problem is either because the spring supporting the door half way up is broken or because the spring must be adjusted.
First perform a door spring adjustment procedure as explained at page 28 in chapter 10 of the Installation Manual.
Here Miele installation manual for the G660. The file is in PDF format.
If the regulation procedure does not do the job, then the spring must be replaced.
This video shows how to replace the spring (model and manufacturer are different-operations are similar):
The spring is usually sold as part of the hinge assembly.
To get parts or to book a qualified technician call the Miele support number listed on the owners manual or use the Contact page on your local Miele website. Here UK website: Miele - Contact Us.
Regards.
Ginko
Nov 05, 2011 | Miele 24 in. G638 Plus Free-standing...
F14 problem with miele
this fault means low pump pressure in the circulation pump due to foreign particles jamming up the pump. you would need to remove the unit and tip it on it's side and remove the base plate and the pump and clear the blockage.
Aug 26, 2010 | Miele Premier-Plus Built-in Dishwasher
F14 code Miele Dishwasher
This fault is low pump pressure. more than likely you have some foreign particles jammed in the circulation pump. you would have to remove the unit, tip it on its side and remove the bottom plate and remove the circulation pump and clear the blockage. the unit will start and stop and not work until the pump is clear.
Aug 14, 2010 | Miele Premier-Plus Built-in Dishwasher
F13 error code on Miele dishwasher. I can't find
The water valve on Miele dishwashers is built into the end of the water line where it hooks into your plumbing(in that box-looking assembly) Your best bet is to call Miele USA, I have had very good luck with their customer support system, they can usually diagnose your problem right over the phone.
Technical Support
Residential Appliances Hotline
(800) 999-1360
Monday-Friday: 8:00 am - 8:00 pm EST Saturday-Sunday: Closed
http://www.mieleusa.com/usa/contact/contact_miele.asp?page=1
Apr 20, 2010 | Miele Premier-Plus Built-in Dishwasher
What does F12 mean on a Miele dishwasher?
Water pressure too low. Possible plumbing issue, hose kinked or flow meter faulty
Mar 14, 2010 | Miele Premier-Plus Built-in Dishwasher
Miele G660 dishwasher upper spray arm retaining circle broken, where can I get a replacement please?
Simply phone agent ,quote them the model and order the item. Miele is a good unit so spares should be available
Sep 20, 2009 | Dishwashers
Miele G660 premier dishwasher
There is a solenoid that opens the door to the dispenser. You can check it with a volt/ohm meter. Sometimes large dishes can block the door keeping it from opening. I personally know on some Whirlpool washers (because it was mine) that if the bottom drawer is put in backwards, it wont let the door open. When I opened the main door, then the dispenser would flop open. You need a meter to check this part if its not the other things. Without it, you are just guessing.
Mar 15, 2008 | Miele 24 in. Novotronic Premier 500...
Miele no heat
The last I checked, the G660 will not work for the G665. If you look under Applicances in your phone book, you will see several appliance repair places. Most of them can get you universal kits to replace this. I however caution however that you should really let a tech look at your dishwasher. Something tells me that boards got shorted out by mistake without realizing it.
Mar 10, 2008 | Miele 24 in. G665 Built-in Dishwasher
Mar 02, 2008 | Dishwashers
Dishwashers Logo
193 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
