Question about Cameras
Sd memory card is locked and wont unlock
Even if i flip the switch on the side of the card it still says its unlocked and my computer wont even read it when i directly connect it to my computer. i gave it to my friend to bring to his camera shop and his boss tried 3 different programs to try and read the disk but it still will not work
  • flamingoo Dec 24, 2008
    my camera says error card locked! but its not i cheked the side of it and its not locked. i put another memory card in it and the same thing happened. i can view my pictures but thats it i cant click any other buttons besides the review and on one
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey rpl2125,
It sounds like you covered your bases, but you could try putting a piece of tape over the write protection switch and see if this works. If the tape doesn't work then there is most likely a defect in the memory card and you are going to need to replace it, and I would contact the manufacturer to see if it is under any warranty, and if it is they will often just send you out a new one.
Go Ahead. Use Us
Posted on May 14, 2008
  • 3 Answers
I just fixed mine had the same problem. Basically you have to take it apart the little lock slide pushes on a little pin which grounds out the card aka locking it if you take it apart carefully, you can take a small screwdriver and bend the tab out a little bit so it doesnt touch. I did it and mine works great now.
Posted on Sep 06, 2010
Where is lock on sd memory card
There's a small slide switch along one side of the card. Slide it toward the contacts to unlock it.
Mar 30, 2017 | Cameras
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Free canon manuals
Take the memory card out of the camera. Move the lock switch on the side of the card to the unlocked position if it is in the locked position. Replace the card carefully without moving that switch.The unlocked position on most SD cards puts the switch towards the end of the card that goes into the camera first.
If that doesn't help, try a different card. The card you are using may have a problem that could require formatting. Copy your photos to another drive first. (Use a drive/photo recovery program on your computer (with the card in an SD card reader). There are some that will attempt to read even a corrupted SD card.) Then reformat the card. If the card can't be reformatted, it may have failed. Check your warranty on the card and see if it will be replaced by the manufacturer.
I hope this helps.
May 11, 2013 | Canon PowerShot SD850IS Compact Travel...
Screen says write protect
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If that doesn't do it, try another card.
Aug 05, 2011 | GE A1255 Digital Camera
I am having an error appear (card locked) when the camera is turned on with the card in it. How do I unlock it. thanks jared
The camera uses an SD memory card to store the photos. Eject the memory card. Hold the memory card face up and right side up so that you can read it (with the label on it). On the left hand side of the memory card there is a small switch. Gentle slide the switch up so that it isn't in the lock position.
Mar 12, 2011 | Polaroid i1036 Digital Camera
What does it mean when the camera says protected card
It means that the memory card is write-protected.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 05, 2010 | Vivitar ViviCam 8380 Digital Camera 8.0MP...
Memory card locked, already tried little switch on the side
It may have to be unlocked in the camera settings. My phone has a lock feature for photos, to prevent accidenta erasing.
Jul 17, 2010 | SanDisk 2GB microSD Memory Card
My computer won't read my memory card
Hello :
Look for a tiny switch on the side of the SD card . This switch indicates[ Lock or Unlock ] . You need to unlock it .
ed57898.jpg please rate!
good luck .
Apr 11, 2010 | SanDisk 2GB microSD Memory Card
Samsung PL50 camera wont unlock memory card
There is a little sliding switch on the side of the memory card. Make sure it is not on lock.
Mar 01, 2010 | Cell Phones
Cameras Logo
518 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
