HP OfficeJet 6210 All-In-One InkJet Printer Logo
Posted on Sep 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why do I have a line down the middle of my scan using the feeder not when I scan on the glass?
Anonymous
Level 2:
Scholar:
  • Expert 44 Answers
  • Posted on Sep 07, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
44
Questions
0
Helped
13162
Points
144
Check the feeder slot for any debris (paper, correction fluid etc.)
Also open the lid so check the platen glass. to the far left should be a narrow strip of glass seperate from the main plate. make sure there are no marks on this, usually correction fluid or ink from ballpens likes to get smeared on here when using the feeder causing a perma black object to be scanned for copying / scanning. hence the mark on the copy / scan.
Wipe carefully with a warm, damp cloth and some window cleaning detergent to remove any marks from there.
BD
  • JStewart02 Jun 01, 2011
    BirdDog,
    Thanks for the tip, as I had the same issue, but hadn't known what to do about it. I was up against a deadline and was able to get it cleaned and fixed. God bless you for your post.
1 Related Answer
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
  • Posted on Nov 16, 2007
SOURCE: Yellow line showing on in scanned pages
if you can open the cover of the scanner just clean the glass and use any lubricant to apply on head rod to move smoother .
bye
Line down middle of scan
only frm the document feeder ? lay it on the glass if the lines gone check the slit glass or if you switch from oem toner to generic or viceversa get a new developer and drum also make surethe fuser dosnt look worn
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
5helpful
Verticle lines appear on document when scanning through document feeder. No verticle lines on document when it is scanned face down on the glass. How do I clean the document feeder?
There is a thin strip of glass next to the main platen glass, where documents fed through the feeder are scanned. You most likely have Wite-Out or some sort of debris stuck to the glass. You can probably wipe this residue off, but if you need to clean that strip of glass, use alcohol and a lint-free rag.
6helpful
What causes a line down the middle of copied pages
There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on.
Line appears on scans and faxes
Do you use the document feeder when faxing and scanning? If so, the line is likely some paper dust, white-out, or other dirt on the thin piece of glass to the left of the main platen glass. Wipe that glass strip with a lint-free cloth, and if that doesn't work try using a little bit of alcohol.
If the line persists, or it occurs when you don't use the document feeder, it's probably dust somewhere in the optical portion of the unit, underneath the glass. If you want to take it apart, you can blow some compressed air around down there to scatter the dust or try wiping down the mirrors with a lint-free cloth.
3helpful
Fax has stipe down middle
When you open the topt cover, there are 2 scanner glasses. A small one a and a big one, the small one is used when using the feeder. Spray some windex direclty on soft cloth and clean the 2 scanner glasses as well as the white reference above( there are 2 small and big). You may even see it, a mark it the middle of the glass.
This should resolve the issue
14helpful
Black line in the middle of the output - scaned document
A black line down a scanned page indicates a dirty scan glass. Lift the top of you scanner like you would putting a page or book down to scan. On the end of the scanner that has the document feeder you should see a thin piece of glass the is separate from the larger glass pane. This is the document feeder glass. Now check it over for a very small mark of ink or dirt. You can use regular glass cleaner to wipe this glass just spray it on a piece of cloth not the scanner then wipe. You may have to wipe and then try scanning several times if the ink or marker is died on. while you are cleaning you should also clean the main glass pane, it will make the scans clearer and crisper.
I hope this helps, if so please rate our solution.
buddy
Corporate Computer
www.ccl-la.com
[email protected]
8helpful
Black vertical lines in copies
You need to clean the glass. Open up the feeder and you have a large piece of glass for scanning and to the left a smaller piece of glass that it uses to scan from the feeder. Clean this smaller piece of glass; even the slightest smudge can leave a black streak.
1helpful
Line down the middle of copies
Clean the **** glass... usually a thin glass to the left.... check with a small flashlight, small blotch of ink or white-out can cause this... hope this helps.....
2helpful
2answers
Dark balck line down middle when copying, but not when printing
If this happens only when you feed the original through the top feeder and not when you lay it on the glass, then you have a small bit of dirt at the scanning location--since the paper moves, rather than the scanning bar, the section of glass that is involved is very small and one little bit of dirt will make a line down the whole page. You need to lift the automatic document feeder mechanism and clean the glass strip under it--that's where your (unseen) dirt is. (Page 108 of the manual, if you have one.)
k24674
Grand Canyon Tech
Grand Canyon Tech
