Question about Olympus Camedia C-350 Digital Camera
Lens barrier will not open - Olympus Camedia C-350 Digital Camera
It will not turn on to take pictures
Posted on Nov 24, 2008
Sony hdr hc9 lens cover problem. It will not open all the way
there is most likely an issue with your "lens barrier unit". this usually will need to be replaced by an experienced technician. www.austintelstarservices.com
Aug 29, 2010 | Sony Video Cameras
Aperture sticky
I'm not sure if you mean the lens barrier on the out side of the camera, the shutter that takes the picture or the high speed shutter.
If the outside barrier is sticky, it may have water soluble stuff on it like jam or syrup.
I clean this area very carefully with a Q-tip moistened with ONE drop of lens cleaner. Carefully clean by pushing the barrier back into the lens sideways, gently, and cleaning under the edge of the lens cover slightly. This is easier to do if you remove the batteries from the camera with the lens out.
Caution - you CAN jam the lens barriers. You can pop out the barriers. I suggest getting a shop to look at it.
Apr 02, 2010 | Cameras
I cant find the on button
Open the Lens barrier to turn the camera ON and by closing the Lens barrier, you will turn it OFF.
Please let me know if that helps..
Thanks and Regards,
Srinivas
Apr 14, 2009 | Olympus Camedia D-390 Digital Camera
Lens cover opens only a **** on Sony DSC-W80
Please read carefully below procedure how to remove "Barrier Block" (what you call Lens Cover)..
Turn camera power ON so Lens will extend.
Take out battery so lens will remain extended.
First silver ring needs to be removed with help of tweezers as shown in below image..
Now you will see 2 screws at front of lens, unscrew to remove barrier block (lens cover) as shown in below image..
You need to have new barrier block with following part number..
A-1205-001-A BARRIER BLOCK ASSY
Subject part is available in Part Store
Install new barrier block as shown following image..
Insert battery and power up camera to check does barrier block works fine.
Need further info, let me know.
Good luck.
Feb 10, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Shutter
Do you really mean the shutter? Or do you mean the lens barrier? The lens barrier opens in front of the lens when you go to take a photo.
Assuming it is the lens barrier which is stuck open, the cause is usually dust/grit. A series of "puffs" with a large bulbed blower, e.g.a Giotto, should help clear it.
If it's been caused by liquid ("coke" is a favourite!) then the sugar is holding it open. A little (very little) ethyl alcohol dropped on the lens and allowed to percolate around the barrier area should sort it.
If it is the shutter you mean, then that is a workshop job.
Apr 05, 2008 | Panasonic Lumix DMC-FX8 Digital Camera
Lens doesn't open
Just to clarify, are you having trouble opening the protective flaps/barriers that cover the lens? Or are you having trouble getting the lens to physically extend out like normal (you have to twist it to get it out)?
Nov 20, 2007 | Cameras
Shutter Won't Open
Well, replacement of the shutter unit (lens barrier)instead of the repair seems more realistic... The part number is: 178739811 Please contact your nearest Sony Service for the price estimate. If you need more info please advice. Arpi
Mar 09, 2007 | Sony Handycam HDR-HC3 HDV Digital...
Lens Cover won't fully open
Hello Tomkimball, the solution for your problem is in replacing the lens barrier. Part number is 178727811. Best regards, Arpad
Oct 30, 2006 | Sony Handycam DCR-HC90 Mini DV Digital...
Olympus Camedia C-350 Digital Camera Logo
76 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
