Question about Sony Cyber-shot DSC-W55 Digital Camera
Just purchased 2 polaroid sd memory cards (2 GB) Neither one will format in my c530 camera.All i get is a Filesys Error e00100. They will work fine in my older CX4230 camera.Am I doing something wrong or are they just not compatable to the c530.
    Genius:
  • Sony Master
  • 1,673 Answers
Check the recomended card list that is in the instructions for your camera if there is one. Call the dealer or the tech support to find out about a compatable SD card for your camera model. I have seen some models of cameras not respond to some types of SD cards even though the fit in to the socket.
Jerry G.
Posted on May 14, 2008
Inserted 4G memory card...says memory card is full...when I try to format the card, get filesys error e00100.....
The C330 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and won't work. You need to go with cards 2GB and smaller.
Jan 11, 2011 | Kodak EasyShare C330 Digital Camera
I have not been able to format SanDisk SDHC 4GB Memory Card on my Kodak Easyshare Digital Camera C530. I am regularly getting the message "FILESYS ERROR e00100. The Memory card is authintic & NOT...
The C530 uses MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use MMC or SD cards, 2GB and smaller.
Nov 01, 2010 | Kodak EasyShare C315 Digital Camera
I purchased a new memory card for my kodak easy share c530 camera and it will not format it. I keep getting an error message filesys error e00100.
Check the specifications of the camera. The card may be an SDHC which may not be compatible with the camera. SDHC is relatively new and will not work with most older cameras
Mar 27, 2010 | Cameras
Bought a memory card for my Kodak 'EasyShare' C530 and I don't know if it's the right one. I bought a 2GB Memory card with MMAGFQ2WDCA-D8 on the back of the card itself. The error message I get is...
There are regular SD cards and high-capacity SD cards (HCSD). Some devices are not compatible with HCSD cards. It sounds like your camera is not compatible. You may still be able to purchase 2G & 4G regular format SD cards that will work fine.
I hope that helps.
Mar 20, 2010 | Kodak EasyShare C315 Digital Camera
Kodak camera 2 gb memory card will not work
Format it in a PC using a card reader. Then use in the camera.
Aug 10, 2009 | Cameras
I have a new 2 gb dane-elec memory card and when i turn on my camera it says the memorty card is full and when i try formatting it it says filesys error e00100
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
May 22, 2009 | Kodak EasyShare C330 Digital Camera
Filesys error e00100 when attempting to format a Scandisk 2.0 gb memory card.
Hi ,Welcome
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 02, 2009 | Kodak EasyShare CD33 Digital Camera
    Kodak c310 camera won't format new SD 2GB card old card same size
    Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
    Mar 22, 2009 | Kodak EasyShare C310 Digital Camera
    FILESYS ERROR E00100
    Which size has the card?
    Is the write protection enabled?
    Click
    Dec 20, 2008 | Kodak EasyShare C330 Digital Camera
    Formatting c530
    Your camera will only accept a 1gb card Max! Go to www.kodak.com/support
    May 24, 2008 | Kodak EasyShare C315 Digital Camera
    Sony Cyber-shot  DSC-W55 Digital Camera Logo
    63 people viewed this question
    Top Sony Cameras Experts
    james laughton
    james laughton
    Are you a Sony Camera Expert? Answer questions, earn points and help others
