Question about GRY Viore RPT50V24DHD 50" HDTV DLP TV
My grandson was pushing the only button on the front if the 50 inch viore and now it wont stay on but maby a min'
  • 10,594 Answers
If tv wont stay On and turns Off that shows problem either with power supply board or lamp has been reached to end of its working life.
If lamp has not been replaced in tv in last 2-3 years, then replace it as weaker lamp can cause such problem as well.
Local tv repair shop will help you to replace lamp.
Hope these info will help you to solve tv issue.
Thanks.
Posted on Sep 08, 2010
  • 666 Answers
What you will want to do is go into the users guide and find the reset factory defaults option usually it involves holding a button or two while starting the device however are sometimes very different this will ensure any setting that could have been changed are restored to there original setting it may take some to reprogram but if after doing this it still does not want to work it sounds like your grandson may have blown the fuse inside the tv or the power source and will require technical aid in order to replace if the tv is still under warranty i recommend returning it rather than paying for the technician to look at it however the part is very cheap so labor should be your only concearn and it isnt much to open on up and slap a new fuse in if you know what you are doing
hope this helps
Robb
Sound goes away
Perhaps. Sounds like an MTS decoder problem.
Apr 14, 2014 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Viore tv code for ge remote 24865
Just do a code search method, rather than seeking code list to this remote. If the remote have pr-loaded code for Viore TV, this proceeding will help you. If not, you have to buy an other remote control, which have setup codes for Viore TV in its code list.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
If you succeed, there is a way to retrieve the code that was synchronized with your TV. To get more details about it, visit this site 'Electro-help'. Type in 'electronicshelponline.blogspot' to your browsers search box, and click search. It is a blogspot site, in English language. Pull up older posts there. Have all details about codes, code search, retrieving the code etc:-
Jun 23, 2012 | GE 24965 Remote Control
Were is it located
I have a cc button on my remote also . Maybe it got bumped. My dog sat on it once and turned on the captioning
Jan 13, 2012 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
I'm trying to reset my viore tv but it want stay on long enough
My Stand By light,Timer/Temp light,Lamp light is blinking. My T.V will come on for just a few minutes then it shuts off. then my lights flash on and off.
Mar 12, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
My viore tv wont stay on it keeps going off by its
Ur tv the projection lamp,inside the tv now,been on an in used about 4 or 5 hours a day,the bulb been inside tv about 1 1/2 or 2 years?The projection lamp life is over,reqiure changing?Turn tv on hear alot of clicking too?The board call the Ballast board also require changing too,this Ballast board help to ignite the projection lamp.
Jul 24, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
My sony wega tv will not stay on,it goes on to standby alternating between a green light and a flashing red light.I cannot find the manual. What should I do?
i have a 50 inch wega that i just replaced the lamp. it wont stay on. i lose the pictuer and sound after a min or so then lose it for a min then it comes back on???
Jun 26, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My hdmi connection wont stay on on my vior plasma 42 inch
You may have used Monster cables which can expand the plug in the TV.
Sorry, but you'll need to get a new input or use tape to hold it in.
Jun 12, 2010 | Toymax Viore 42 in. Plasma TV
My TV will not Power On
Hi, this will happen if your power supply board is failing to regulate the proper current and distribute it through out the set. if you unit will not power up when you push the power button, this will confirm power board failure.
simply replacing the power board assembly will fix this issue.
May 21, 2009 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
VIORE LCD TV/DVD won't turn on
19 in wont turn on. red light just solid , unplugged for a day still same , is there a reset button
Aug 18, 2008 | Televison & Video
GRY Viore RPT50V24DHD 50" HDTV DLP TV Logo
206 people viewed this question
Top GRY Televison & Video Experts
Electro Med Services...
Are you a GRY Televison and Video Expert? Answer questions, earn points and help others
