Question about Dell 1125 All-In-One Laser Printer
It says that my Printer drum life exceeded, I ordered two new drums from Staples and neither of them work on my Dell MFP 1125. Please help?
SOURCE: dell 1700 image drum
After you replace the imaging drum, you should reset the imaging drum's counter. To reset the counter, YOU MUST LEAVE THE DOOR OPEN AND THEN press and hold the Cancel button until all lights flash in sequence.
Posted on Oct 02, 2008
SOURCE: 1720 Dell Laser printer Photoconductor Problem
I finally figured it out (with Dell Tech Support's help)! When you replace the drum, you MUST reset the counter as well. All you have to do is:
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
GOOD LUCK, EVERYONE!!!
Posted on Apr 16, 2009
SOURCE: Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
Posted on Jun 03, 2009
komguy
  • 2306 Answers
SOURCE: Reset the Drums on Okidata C5510 MFP Printer
Yes, you have to install a fuse in each drum unit, it's a littelfuse # 251-062. You can use google to find the procedure.
Posted on Jul 03, 2009
SOURCE: 'DRUM CARTRIDGE END OF LIFE' MESSAGE
The back right of the drum has a small 20mm F80mA fuse that you need to replace to reset the drum counter.
(fuse blows to reset the drum life setting)
Posted on Nov 04, 2009
In the display is the text "drum end " is there a problem with my printer
No. It is common that the drum will reach the end of life at some point. You MIGHT (I dont know if you can for this model or not. I can not find any documents stating that you could or could not) be able to clean the drum. I suggest to contact Konica Minolta if that is possible. If not you will have to purchase a new drum that will work for your model.
I have provided a link below to the supplies for your model from the manufacture.
http://printer.konicaminolta.com/Canada/products/mfp/mc2490MF/supplies.asp
Dec 17, 2012 | Konica Minolta magicolor 2490MF Laser...
Our dell laser printer has our drum life has exceeded what does that mean.
It means that the printer has calculated that you have made the maximum number of prints that the manufacturer has calculated that the drum can effectively do before the prints shows signs of spotting or fuzziness. Strictly, the drum cartridge should be changed, but if the print image is still good and the printer still works, leave it in. The printer drum cartridge will be rather pricey, somewhere between $50-$100, depending on model.
Apr 29, 2011 | Office Equipment & Supplies
It says "DRUM LIFE EXCEDDED"
Hi!
The thing is that you need to replace the drum unit on the machine witch can be purchased at your local dealer!!
Good Luck!!
Jan 13, 2011 | Dell 1125 All-In-One Laser Printer
Dell Mono Laser MFP 1125 says no toner found invalid toner it just flashes the above i just added a new cartridge
double check the one you installed to ensure it was installed correctly. You can do this by removing it with the power turned off then reinstall it. Try to power it back on.
Spanish speaking available for all problems Thank you for allowing us to help, please respond with further questions and concerns
Jan 09, 2011 | Dell 1125 All-In-One Laser Printer
I can not receive faxes on my Dell MFP 1125
Hi, I have Dell 1125 All-in-One Laser Printer. I can send faxes by going to fax option and dialing the number.
How can I set it up to receive faxes? keep in mind that I have only one phone line which I use for both phone and fax.
How can I set the ringers in a way that for example at 4th ring goes to answering machine and at 6th ring goes to fax?
I really appreciate it.
Need help fast :)
Mary
Aug 03, 2010 | Dell 1125 All-In-One Laser Printer
How do I reset the drum counter on the a Brother MFC-7840W???
open the front cover of the machine then press clear back it will say replace drum? press ok
the quality will probably start getting pretty bad as you will be using the drum passed it's life
Mar 22, 2010 | Brother MFC 7840W Printer
Dell 3000cn drum cleaning?
Do not try to clean the drum. The drum and its asociated cleaning blades and other parts, are COMSUMABLES that have a certain useful lifespan, the same as batteries or automobile brake pads. When smudges appear on the drum, it and the associated parts are at the end of their useful life. Order a new IMAGING DRUM KIT from www.dell.com
Aug 06, 2008 | Dell 3100cn Laser Printer
Fatal error
Fatal Error K (for BLACK) - Black toner or drum problem, Drum life exceeded? Display would of said black drum near life before failing.
May 15, 2007 | OKI C5100n Laser Printer
Dell 1125 All-In-One Laser Printer Logo
1,089 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
