Question about Asko 24 in. D3112 Free-Standing Dishwasher
The soap container will not open during the wash cycle. The soap is still there after the whole cycle including drying is done.
  • Asko Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Sep 10, 2010
Secondary soap dish won't open
i think you mean jet dry compartment.change dispenser. in some cases there is a kit but its better to replace new dispenser
Mar 02, 2010 | Dishwashers
My soap dispensar inside does not open during wash
its just a bad (failed ) dispenser. replace it . this should correct problem . mm
Dec 07, 2009 | Washing Machines
Soap dispenser door does not open during wash cycle. it can be opened with the manual release.
close the soap door and put into diagnostics. most models you can do so by pushing heated dry-normal-heated dry-normal. let it do its test and if the soap door opens during the test cycle, most likely the soap door assembly needs to be changed.
Nov 17, 2009 | Whirlpool Dishwashers
Soap dispenser doesn't open for wash cycle
I noticed you didn't rate out chat and saw that your problem was posted. I'm happy to continue to help you if you encountered problems or were not happy with the solution in your chat session.
Jul 07, 2008 | Frigidaire FDS251RJ Free-standing...
Lost manual, wheres rince aid comp
forget the built in rinse aid, it only works for a couple minutes during the whole wash cycle. go out and buy the rinse/aid or jet/dry package that hangs on the racks and works during the whole cycle. of course use only cascade powder soap and sparingly.
May 27, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dry Dishwasher Soap Still in dispenser after wash.
so here it is...
get a screw driver (you may need a "star" head driver as well), get in there and take out all that you can and clean it (it all comes out pretty easily)...you will find a lot of undisolved soap and hard water build up...rinse it, scrape it, vacuum it...just get out as much as you can...keep note of how you took it apart so you can put it back together...then put 1/2 to a whole gallon of vinegar in and run a cycle (hi-temp if you have that option)...if it was like mine most of your sprayers were gummed up and the water just wasn't moving through the machine...
to avoid this problem...use half of what you have been using of your detergent...and only fill the "pre rinse" section if you are doing pots and pans....and then only fill that half way as well.
after that run a few cups of vinegar through on an empty cycle once a month...
whole job (not including the wash cycle) 1.5 hours...
Apr 05, 2008 | Kenmore 16372 / 16374 / 16379 Built-in...
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
Jan 16, 2008 | Maytag 24 in. PDC3600A Built-in Dishwasher
Problems with my dishwasher
You need to replace the dispenser or possibly the wax motor on the dispenser. I would be more than happy to help you. But need to know the brand an model # so I can make sure that I give you the proper advise.
Dec 31, 2007 | Dishwashers
Asko 24 in. D3112 Free-Standing Dishwasher Logo
174 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
