Question about Cell Phones
I am trying to pair my centrios bluetooth headset with my iphone and the iphone is asking to enter a PIN. Where can i find or set this? Thank you.
Just enter 0000 as the pin
Posted on Nov 20, 2010
I need paring instructions for my HS850 to my Iphone.Both from the HS850 and the Iphone side.
To pair the bluetooth headset with your iPhone. Switch on the headset. Then in the iPhone goto settings then bluetooth you can see the iPhone is searching for devices. If it sees your HS850, just click on it and when asked to enter a pin, give in 0000.
Once the iPhone knows your device, I should find it every time both are switched on. (Bluetooth must be switched on on the iPhone)
Jul 12, 2014 | Motorola Mobility HS850 Consumer Headset
A friend connected a android phone's bluetooth to my itower. it worked, but now my iphone bluetooth does not connect. Can anyone please help me!
Pairing with iPhone
  1. Connect the iPhone Dual Dock or iPhone Bluetooth Travel Cable to a USB 2.0 port on your computer (not on the keyboard).
  2. Connect iPhone and the headset to the dock or cable. The headset pairs with iPhone automatically.
Pairing iPhone Bluetooth Headset with another Bluetooth-enabled deviceTo pair the iPhone Bluetooth Headset with another wireless device, such as a Bluetooth-enabled phone or computer.
Step 1: Set the headset to be discoverable
  1. Turn off the headset.
  2. Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
    The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
  1. On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
  2. On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000.
See the instructions that came with your other Bluetooth-enabled device for more information about pairing it with Bluetooth devices.
Apr 13, 2013 | Apple Soundlogic Itower Speaker Works W/...
I just need a pin number so i can pair my headset to my iphone
On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000. let me know does thsi help regards golu_fixya
On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000. user_offline.gif
Aug 29, 2010 | Cell Phones
How to connect plantronics 330 bluetooth headset with my iphone 4
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
Jul 20, 2010 | Plantronics Explorer 330 Headset
Can i pair my new iphone with a used plantronics 220
Yes, sure. Begin with the headset turned off. Then, press and hold the multifunction button until the blue and led lights flash alternately. The headset is in pairing mode. Now, make your iPhone's bluetooth application ('Home screen > Settings > General > Bluetooth') search for new devices. After a while, the heaset will appean on the phone screen. Select it and command the application to proceed. If a pairing code (or PIN, or passkey) is resquested, enter '0000' (four zeros).
Hope it works for you.
Cheers! Carlos
May 14, 2010 | Plantronics Explorer 220 Bluetooth Headset...
How to pair with iphone
Hello
1.From the main home screen of the iphone open "SETTINGS".
2.From the setting menu go to "GENERAL".
3.From General go to "BLUETOOTH".
4.In the Bluetooth menu you will see an on/off switch. Make sure you turn the switch to "ON".
5.From here you want to go to your bluetooth headset. Hold the on button for about 5-10 seconds until the light starts blinking. Once light is blinking go back to iphone.
6.In the Bluetooth menu (same as step 4) your iphone should have discovered your bluetooth headset. However if it is not paired yet. Open the headset menu.
7.In the headset menu you are required to enter the appropriate PIN number (which should be given inside your bluetooth headset instruction manual).
8.After you have entered the correct PIN number press connect.
9.From here your Bluetooth Headset should be connected and ready to use.
NOTE:Fully charge your bluetooth headset before syncing it to your iphone
Goodluck
Apr 16, 2010 | Samsung WEP410 Bluetooth Headset Wireless...
Iphone bluetooth codes
Unless the code has been changed, the default code is 0000 (four zeros). Be sure the phone's bluetooth setting is turned on and discoverable. Next press and hold the headset's power button until the light turns on steady. Then using the phone select "search for a new device", when it discovers the headset it will ask for the PIN number, enter 0000, then select pair. It should take only a few seconds. When done be sure to turn discoverable off so other bluetooth enabled devices cannot access your phone. Good luck to you
Oct 17, 2009 | Apple Cell Phones
Iphone and headsets
Yes, you can pair your iPhone with any bluetooth headset. I have used many different Plantronics headsets and all have worked perfectly.
On the iPhone, go to Settings (the gears icon), click GENERAL, then Bluetooth and make sure it's switched to "On". Then, follow the pairing instructions that come with the headset.
Oct 07, 2009 | Motorola Mobility Bluetooth...
Pin for Motorola H500
The pin for most bluetooth headsets is: 0000
Jan 20, 2008 | Motorola Mobility H500 Wireless Headset
Cell Phones Logo
440 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
