Question about Roper RT14DKX Top Freezer Refrigerator
Freezer doesn't defrost, when i put an ohm meter to heating element it showed a direct short. I registered 70 volts to defroster. I can't find the schematic, whats the problem.
  • Roper Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 12, 2010
Frigidaire Refridgerator keeps going through the defrost cycle
the defrost cycle should come on about every 8-12 hours. You may have a defrost timer issue? I suggest testing it and the heating element with a multi meter.
Ur timer may be activating to fast for each cycle
The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section.
u can get by and test manually by placing a small ***** driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required
God is so good: so this is why I give free advice so please thank him not me.
Mar 29, 2016 | Frigidaire Refrigerators
Frost build up in fridge and freezer only maintaining -5 temp??
Freezer Frost Repair
Fridge/freezer freezing up- and no fan or air circulation:
first check the defrost terminator thermostat it may have gone out. Thus not allowing the heating element to melt the ice.
AT TIMES The fan usually stops working AND CAN MAKE FUNNY NOISES AS WELL due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section.
u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
https://www.youtube.com/watch?v=6SJN8oaA2XE
https://www.youtube.com/watch?v=buX9KcZo2c0
https://www.youtube.com/watch?v=gVXT7pZyk_o
Refrigerator Repair Frosting up in freezer not cooling Admiral RSCA207AAM Freezer Frost Repair Kenmore Whirlpool refrigerator frost build up in freezer not cooling...
Mar 17, 2016 | Frost Refrigerators
Have a diplomat apm 6842 how do you defrost freezer
the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Mar 23, 2015 | Refrigerators
Samsung refrig
Fridge freezing up and no fan or air circulation:
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Jul 29, 2014 | Samsung RSG257AARS (241 cu ft) Side by...
Freezer frosts up and food gets soft
Repair the defrost system, defrost timer,defrost thermostat and defrost heater.
Aug 18, 2009 | Refrigerators
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
DOES NOT MAKE ICE
Aug 13, 2009 | Freezers
Refrigerator portion temperature has dropped to 65-70 degrees even on highest setting. This is an older model manufactured in 1992 with the freezer on the top. Serial # GG516729.
Aug 12, 2009 | Refrigerators
Coils inside freezer keep icing up.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model of fridge)
Aug 08, 2009 | Refrigerators
Roper RT14DKX Top Freezer Refrigerator Logo
167 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
