Question about Sony Ericsson K810i Blue Smartphone
Can i.use a flash light as a torch on k810i ?
K810i change language
I'd recommend reflashing your K810i via the Wotan website. You can browse & find a Dutch language version. It's all explained online. Cost is 1.99 Euro for five flashes.
This service doesn't unlock your phone (it's unlocked anyway) but it will remove carrier branding on either a locked or unlocked handset.
Sony Ericsson K810 Firmware Flashing
Feb 01, 2014 | Sony Ericsson K810i Unlocked, Cyber Shot...
Tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
K810i how to reset the old password?
The easiest way is by reflashing it via the Wotanserver website. This is quick, easy and cheap - only 1.99 Euro.
Sony Ericsson K810 Phone Password Reset
During Firmware Flashing your K810 Phone Password is reset and disabled.
Mar 01, 2013 | Sony Ericsson K810i Unlocked, Cyber Shot...
How can i use the flash light as torch
There is a certain application that can turn your flash light into a torch . Here are some search results in one of the biggest applications websites of cell phones . Just find , what you are looking for and don't forget to rate please ! http://www.getjar.com/mobile-productivity-applications/torch/?o=bestmatch
good look .
Jan 29, 2010 | Sony Ericsson K790i Cellular Phone
How can i use the flash light as a tourch
use your camera to use your flash light as torch.swipe the camera lid.enter the options menu there will be a flash light option.turn it on and use the flash light as torch.
Oct 07, 2009 | Sony Ericsson K790i Cellular Phone
I need torch light
It is simply not possible because K800i is equipped with a xenon flash, not an LED flash as was the case with K750i and W810i. Xenon flash provides significantly more light than LED flashes, but it isn't designed to work as a torch light, it's just not possible.
Apr 03, 2009 | Sony Ericsson K800i Cellular Phone
How to flash K810I
Yes you can Flash , but need to have xs++ and make sure you have correct Custpack -- the raw data
Feb 12, 2009 | Sony Ericsson K800i Cellular Phone
Mobile phone not charging
hi, you need to go to the sony ericsson support site http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/k810i?cc=gb&lc=en , download the software updator( you will find it if you have a look aroud) once downloaded follow the instructions to update your software, this will flash your phone with software that will fix it..
hope it helps
ps leave your phone to charge for an hour first even if it seems not to be doing anything
Nov 27, 2008 | Sony Ericsson K800i Cellular Phone
K810i while switch it on red led blinking
http://youtube.com/watch?v=QgeveIa25HY Click on this and follow the instructions. It works. If you have a flashing led when trying to switch on....
Jun 03, 2008 | Sony Ericsson K800i Cellular Phone
I flashed my phone
flash completely i.e,
1.main file.(.mbn)
2.fs file.(.fbn)
3.customization files(.zip)
use se tool2lite 1.11 to flash ur k810.
May 31, 2008 | Sony Ericsson K810i Blue Smartphone
Sony Ericsson K810i Blue Smartphone Logo
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
