Question about Samsung HP-R4252 42 in. Plasma HDTV
It turns on and off
The tv turns on and off by itself, and sugestions
  • evoljay May 19, 2008
    i have a hp-r4252
  • evoljay Jul 03, 2008
    there is 2 main board, the x and the y, is that true???
  • 44 Answers
Replace the main board, common problem.
Posted on Jul 03, 2008
  • rlamkin
    rlamkin Jul 03, 2008
    The X & Y drive the display, if you have a picture they are not the problem. There is only one main board
Hannspree tv
It sounds that the main system control memory IC is faulty. This is a common trouble to all TVs, irrespective of brand.
It is a very small IC, will look like this, and can be located very near to main system control IC. Won't cost more too. Replace it.
Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jun 03, 2013 | Televison & Video
My sony rear projection tv's red light started blinking 8 times, so I removed the high vltage splitter, so I needed to test the block. And you guys are sugesting for me to turn on the tv, now do I
Turn on very briefly and make sure the large red wire that entered the block is well away from any metal---if hear a frying sound and blink sequence is gone the block is bad( I used to put the wire into a old soda bottle as it has over 20 thousand volts coming out of it, much like the spark plug wires in a car---high voltage with low current.
Nov 01, 2012 | Televison & Video
Hi i have a 40inch bush tv my partner was using this for his computer screen last night like he does all the time but for some reason it turned itself off and now wont turn back on. The standby button is...
Is there anything power signal lights?If there is no signal power lights,it is totaly dead set no power.First step is to check the power outlet,then the AC cord if there's a ac power.If the AC cord is good,check the fuse,located at the power supply.Replace same value of fuse if busted.Try this sugestion or procedure.Thankss...
Aug 26, 2011 | Bush Televison & Video
I have a panasonic th-42px70a you turn the tv on and then it turns itself off
That symptom of your televisions have problem in power supply.The power supply have some deffective parts like the capacitor.The capacitor is totaly leak that cause of voltage drop.The output voltage dosen't continue because of leak capacitor,the leak capacitor is mildly shorted.So try to check the capacitor and replace all leak capacitor.The leak capacitor can identify through visual checking if you don't know how to use capacitor tester.The leak capacitor is rounded shape at the top and sometime have moise.Try this sugestion.hope will it help you.Thank you..
Aug 26, 2011 | Televison & Video
After 2 seconds my monitor HP w1907v is switching off itself and there's no way to bring it back to life again. If i switch off and on again the monitor shows images for 2 seconds and then dies. I...
Well the monitor obviously works, so I see no reason to open the case on the monitor especially because there are no user serviceable parts within the case. my sugestion is to try the monitor on another PC if that yeilds the same results then I am wrong and the problem lies with the monitor. I believe the are two types of connections for this monitor shane_barnha_2.jpg VGA and DVI shane_barnha_0.png
Next step is to try the one that you have not tried yet if that fixes it then the problem lies in the output conection on the back of PC the input connection on bottom of monitor or the cable itself. If there isn't a second connection like I think then the next option would be to try another monitor, which if you do not have available can be achieved by using most new flat screen TV's If you have a TV With the same conection Just move the PC or TV close enough to try, Use your remote to change TV input to PC then turn TV off connect cable turn TV on and start up your PC if this works you will need to have your monitor repaired or replaced.
Thumbs Up if helpful, Feedback is Appreciated!!!
Good Luck!!!
Jun 18, 2011 | HP w1907 LCD Monitor
My tv remote is not working, I bought a universal remote and still not working. I programmed the new remote to my Sony tv and it worked fine. I beleive is the tv itself, any sugestions? Thanks for the...
there may be an issue with the ir sensor board in the tv. you could use you serial number and model number to research the part to replace (rather inexpenisve part) or have a vizio certified repair company diagnose the issue and theyll replace the board for you.
Nov 20, 2010 | Vizio L32 32 in. LCD HDTV
I HAVE A SONY KDF-60XBR950 , AUDIO IS FINE BUT NO PICTURE. AND BULB IS GOOD SCREEN IS LIT UP. ANY SUGESTIONS
Take out the plug and hold down the power button on the TV itself down for a minute then plug it back in and turn on your TV it should be working perfectly fine after that.
Sep 17, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Camera turns self off
Take a Q-Tip "dampened in rubbing alcohol. remove the battery and clean the two or three contacts at the base of the compartment.
Aug 30, 2009 | Polaroid i835 Digital Camera
TV turns off by itself
Check the interlock switch on the rear lamp cover. Sounds like the cover might not be seating completely, allowing this safety switch to shut the TV off. When you remove the cover, it's just to the left of the big black plastic ventilation guide for the lamp, and it's a little tiny blue lever that moves up and down. Make sure the wires going to this switch are OK (not pulled out or 'hanging by a thread').
Jun 09, 2009 | Samsung HL-S6187W 61 in. HDTV
I have a a insignia lcd tv model ns-27lcd turns off by itself
The problem is most likely the fuse connected to the power wires. You have to take apart the TV and follow the power wire to the fuse. Fuse number is T4AL/ 250v. It will be labeled above the fuse. We had the same problem. Also, check to see if the metal around the tops and bottoms of fuse are loose.
The way we fixed it was to wrap aluminum foil around the fuse and put it back in. It is only a temporary fix until we can get a fuse. Hope this helps.
Aug 07, 2007 | Insignia IS-LCDTV32 32 in. Television
Samsung HP-R4252 42 in. Plasma HDTV Logo
Jerry Greenberg
Jerry Greenberg
