Question about Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher
Viking dishwasher vud141 door lock how to open??
Repairing heat selector switch undid door screws and latch screws and by mistake shut door --- how can I get it open again - Please!!!!
Thank you, Paul
5 Suggested Answers
SOURCE: viking vud141 - timer does not end the cycle
you can try this number 305-418-0010 they have everythin for viking product and very cheap
Posted on Feb 05, 2008
SOURCE: Dishwaster Viking VUD141
The floatswich down the bottom tray has aktiwated there must be a leak,(.water in the tray)
whether, upper conection nut between chamber and hose circulationpump .I had tha problem.
Greetings Frank
from Germany
Posted on Nov 08, 2008
  • 3513 Answers
SOURCE: I am looking for a
Please check the bellow link for the manual …
Let us know if you have somethin more to ask else accept the suggestion.
Thank You for contacting Fixya
Posted on Aug 19, 2010
  • 1902 Answers
SOURCE: Viking Dishwasher Vud141 circulation pump
Hello & Welcome to FixYa
If the water fills fine and completely, then it means that the circulation pump is bad however, as you have already checked the pump and that is working then test the float switch located inside the bottom front of the unit. Please get back to me if you have any other questions.
Posted on Aug 24, 2011
How to instaal viking detergent dispenser
remove kick plate, bottom access panel, door panel and door latch (careful with the wiring) and than remove the 6 screws and 2 brackets holding soap dish.
Jan 16, 2011 | Viking 24 in. Professional Series VUD141...
The soap dispenser no longer closes and I see that my dishes aren't getting as clean as they should. It appears the closure clasp/hook has lost a piece so that it doesn't catch the lid. Can the entire...
Hi- Yes, you need replace the entire dispenser. Viking dishwashers are actually Askos on the inside. It's not too hard to replace if you are handy and can get the part from Viking directly. Unplug the unit or shut off the breaker and remove the front panel by removing the screws around the outside edge of the door. I believe the dispenser is held on with brackets (it's been awhile since i replaced one on an Asko or Viking). It should be pretty evident how to remove it once you have it opened up. If you are unsure at all call Viking and they can give you the number of a Tech. Good luck.
Sep 24, 2010 | Viking 24 in. Professional Series VUD141...
How do I find the door lock and a door seal (bottom of door) for my Viking VUD141 ?
Don't know about the lock, but the bottom seal for the VUD141 is part # PD100091 (just had mine replaced).
Mar 20, 2010 | Viking 24 in. Professional Series VUD141...
Indesit d63 dishwasher, door locked shut. took top off+got to latch, the plastic catch wouldn`t pull out of the latch. undid it all, all seems unbroken but cannot seem to arrange the latch so that it will...
check with whoever you order the latch from, usually parts are individual for electrical parts and never assume that the screw or washer will come with new one, save every piece.
Mar 09, 2010 | Indesit 24 in. D63 Free-standing...
Machine not starting , door not closing well, no click from locking mechanism
The door latch and or door handle assembly which also holds the door switch may have brocken.
If the door latch does not shut properly, this will not close your door micro switch. And if the switch is not closed then the machine will not operate.
Turn off machine at the power source. Open the dishwasher door. You may want to put some weight on the door to stop it from springing back up.
If you have a star allen key or a star shaped tool, you can open the screws around the stainless steel plate of the dishwasher door. Start with the ones on top, which secure the control panel and door lock. See if you can remove the control panel gently without having to open the screws for the front door panel. Sometimes you may need to loosen the front panel screws to free the top control panel.
Once you remove the panel, you will notice a door handle assembly which also holds the micor switch. Take note of how it is set up. Also examie to see if any plastic parts are broken. You may need to order the complete door latch or door handle assembly and replace.
While doing this make sure the machine is turned off at the power source.
Good luck.
Nov 17, 2009 | Asko 24 in. D3121XL Free-standing...
Dishwasher door locked shut
Apply firm pressure to the door while you press or pull the release latch. The screws holding the latch assembly could have loosened. Tighten screws after you get it open.
Jul 07, 2009 | Dishwashers
Hello. I can help you. Since you already checked out the power, skip that step and look at the latch.
If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Jun 05, 2009 | Viking 24 in. Professional Series VUD141...
Light not going out in viking frig when door is closed
you have a micro switch at the top of door by the door hinge.must remove top vent cover to access. i've found that if the screws (2 or 3 phillips ) get loose the door is not aligned to open and close the light switch . or maybe the switch itself has failed
Nov 26, 2008 | Viking 24 in. Professional Series VUD141...
Viking Professional Double Oven
turn your selector switch to clean and then turn your thermostat to clean. the unit will latch the door and clean for a few hours until the unit cools off and the door latch opens. remove all your shelving before doing this. if you like a manual go to and download your use and care for free
Nov 09, 2008 | Viking 24 in. Professional Series VUD141...
Have a Viking trash compactor VUC181 that will not open. Appears latch is broke. How can I get it open?
I have had this same problem and found two causes. Latch was never the problem.
#1 - Ram not in full up position. To check remove top plate and attempt to run compactor - depressing microswitch when ram is at the top. If compactor will not run you can check the ram position by turning the primary screw drive with a ratchet wrench. When ram is at the top position attempt to open the compactor drawer. The stop microswitch seems to frequently bend out of alignment - check the microswitch positioning before resecuring top plate and adjust if necessary.
#2 - Can (or other debris) is wedged in between ram and drawer. Remove back cover and carefully inspect insides of the unit - use a flashlight. Pry out any debris that may impede the drawer from opening. Attempt to open the compactor drawer.
Good luck,
Jon B.
Oct 10, 2008 | Viking 24 in. Professional Series VUD141...
Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher Logo
41 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
