The center wire doesn't do anything. Its the outer wires. You can get a standard CB plug with 2 wires that will work just fine. If that plug fits, I it will work. My concern would be if the pos and neg are the correct sides. It should be, But I wouldn't know unless I looked at it.
DO NOT HOOK the radio up with the power wires backwards. Or you will blow the polarity protection diodes. They are there to blow if the radio is hooked up backwards.
If you look at the plug. There is a side the goes to a point, and the other side is square. The black wire, Ground, should be on the side that goes to a point. If it does, then that plug is standard.
It's fine to use and hook up in the usual way. Do not hook up the center wire. It does nothing in the radio. You can clip it, and put a bit of shrink tube on the end as so it does not have a chance to short on anything.
If you are not sure about hooking this power cord to your connex, just go on ebay, and get a regualr CB power wire. They are cheap. It should only have 2 wires.
