Question about Whirlpool Washing Machines
My washer dryer 4 years old. Dryer has no heat. Washer will not spin, drum just moves slighly from side to side,
Probably a physical problem of your metal lip spinning onto the plastic white rim which probably deteriorated into small plastic pieces you werent aware was your plastic rim liner
Posted on Sep 07, 2010
Hi my whirlpool doesent speen
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will notturn - 11068202794. ApplianceVideo.com ...
Kenmore / Whirlpool Washer Not Spinning 1 - YouTube
? 11:33
https://www.youtube.com/watch?v=TB_W6sPdzkM
Jul 10, 2012 - Uploaded by Bill Newberry
Kenmore / Whirlpool Washer Not Spinning 1. Bill Newberry ... Washer will not spin the clothes dry ... Now ..
Dec 03, 2015 | Whirlpool Dryers
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
When my washer is on the spin cycle it goes out of balence shuts down no matter wht size load or how i arange the load never completes the spin cycle this is a kenmore elite oasis 5 years old. #2 problem...
as for the washer there maybe a broken spring or where the spring attaches that balances the drum. look for this firest. for the dryer is it spinning around at the right speed if it is then the belt is ok. is it hot inside the dryer after running it when you open the door. if ti is check the dryer vent hose and exterior door at end of hose to see it they are plugged up . if the hose is plugged up the heat and moisture can't excape and the clothes will take a long time to dry.
Sep 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Drum in kenmore top loaded washer is moving freely, loud in spin
YOU HAVE RUBBER WHEELS THAT RIDE ALONG THE BASKET HOW OLD IS THE DRYER MAY NEED TO REPLACE ESPECIALLY IF IT IS A OLDER MODEL
May 03, 2009 | Kenmore 24632 Top Load Washer
Dryer Drum Won't Spin
Reach inside and grab ahold of the baffle. Try to spin the drum, it should have resistance. If it spins freely you have a broken belt. Hope that helps. Dave ww.washermd.com
Dec 16, 2008 | Maytag Dryers
Dryers drum is not spining
I was having a similar problem but my dryer was about 5 years old. There are a couple of rubbery, sticky belts that wrap around the dryer drum. One of mine had come off the drum and was balled up, wedged between the drum and the dryer wall. It wanted to spin, but this "belt" was keeping it from doing so. I'm not sure why or how it happened, but I removed the portion that was gummed up and now it works fine.
Nov 25, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryer not working
If the drum is not moving: There is something stuck inside your furness blower( could be some pice of cloth). Open the furness and remove the piece and your dryer will be working fine afterwords. If the Drum is working fine; the coil valve, fuse or the gas ignitor could be the problem; usually repacing the coil valve will fix the problem
Oct 14, 2006 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
