Question about Whirlpool GEQ9800P Electric Dryer
Whirlpool GEQ9800P Electric No heat
Wow, the manufacturer really doesn't want anyone to get inside this machine. The back is riveted as well as screwed on. How can I access the heating element to remove and test? Or to find any fuses that might have gone bad in the machine?
  • marksmith32 Dec 02, 2008
    My dryer will run, but will not heat. I have 10.1 Ohm through the heater element, continuity through the hi thermal switch, and no continuity through the thermal cut off switch. A local appliance store has a combo pack of thermal cut off switch and hi thermal cut off switch for $29. Will try that tonight and see if it works to switch them out.
  • recarlisle Dec 10, 2008
    same problem, dryer runs but no heat. what is the normal chain of events? I have replaced the thermal fuse with no luck. What should I replace next? And so on, and so on?
  • 1,073 Answers
Remove the bottom acess panel the element is on the right side there are 2 thermastats and 2 safety limits that should read contunity if they are good
Posted on May 16, 2008
How do i remove heating element?
This video will show you how to replace the element on that style dryer
Sep 05, 2011 | Whirlpool GEQ9800P Electric Dryer
My whirlpool GEQ9800P dryer won't start. The light is on inside, and there is no lint trapped in the exhaust in the rear. The lint trap looks OK too. How can I remove the front panel? Will that give me...
It is probably the thermal fuse which you can get access to from the front bottom cover. It is about $15 and most parts stores have it in stock. Need 1/4" wrench to remove. Clogged vent tube is most common reason for this going out so pull out and vacuum out well too. Make sure you unplug the dryer first.
Jan 12, 2011 | Whirlpool GEQ9800P Electric Dryer
I have a Whirlpool GEQ9800PW1 Electric dryer and I opened the door to dry some clothes and the interior light was out so I immediately checked the circuit panel to see if it had blown a fuse, it had not. ...
The fuse to this dryer is inside behind the filter housing beside the thermistor.themobilian_592.jpg
Pop that bottom panel and remove the filter housing to get to this fuse.
Dec 28, 2010 | Whirlpool GEQ9800P Electric Dryer
Dryer is taking too long to dry clothes, even on AccuDry setting for Jeans/towels - it still is heating, just not heating enought to dry clothes, I have been doing two cycles at least for a very small...
Your house vent is restricted causing the long time to dry complaint.
Please clean the entire vent to the outside.
Also make sure the vent behind the dryer does not get smashed when the dryer is pushed back to the wall.
Jan 19, 2010 | Whirlpool GEQ9800P Electric Dryer
Dryer heating element(s) are inconsistent
there is only 1 element. were you taking these readings with the wires on them?
the other 2 were thermostats.was there lots of lint?
sounds like you may have bad thermostat.
Nov 23, 2008 | Whirlpool GEQ9800P Electric Dryer
No Power
look for an "open" thermostat either on the heater can, or a thermal fuse has gone bad, probably shorted out when the element broke.
May 13, 2008 | Whirlpool GEQ9800P Electric Dryer
Whirlpool electric dryer will not heat
check the thermal limit on the side of the heater housing and the blower thermal on the blower housing
the emement limit is at the top of the blower housing and will have 2 red wires going to it
the blower limit will have blue wires going to it
withe the power cord unpluged, remove the wires to these two limits and with a meter on rx 1 ect. read across each of these if you do not get a meter fluctuation , all the way to the right as you check the part os bad
Apr 12, 2008 | Whirlpool GEQ9800P Electric Dryer
My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Jan 08, 2008 | Whirlpool GEQ9800P Electric Dryer
Whirlpool GEQ9800P Electric Dryer Logo
160 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
