Question about Compaq Computers & Internet
Hp laptop won't turn on and the power pack makes a clicking noise ,can it be repaired ?
  • 4 Answers
There could be a short circuit in the powe pack.
Just call HP and have the power brick replaced. try using another power pack to isolate the issue, if your laptop works using another power pack, then its your power pack that causes the issue
Posted on Sep 07, 2010
HP pavilion HP Pavilion 15-p087sa laptop is not powering on and making ticking noise.
Hello
It's might be the fan that's making the noise or can be something worse then that, I would recommend ask them for repair if it is still under warranty.
Dec 03, 2014 | HP Pavilion Computers & Internet
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
Hp Compaq nx9010 Won't connect to Internet
install the latest service pack, i'm sure that's probably the issue, the early version of win xp didn't like to cooperate with wpa or wpa2. to check which service pack you're running (i assume xp because that's what came stock on those) click start and go to my computer and right click then go to properties, it will tell you which service pack you're running. the latest is service pack 3. honestly if i were you i'd just do ALL the updates as there are many security updates and patches you should have.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 09, 2012 | HP Compaq Business Notebook NX9010
My hp 4510 powered off while in use and won't power back up. Can you tell me the problem?
Please turn on your laptop back and please check your CPU fan, make sure your laptop CPU fan is running without failure. That fan maybe set to auto on/off but make it sure that fan will running when your laptop become hot. I also recommeded you to flash lastest Bios to your laptop. You can gte Bios software at manufacturer website and find " Download Driver / Software "
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 30, 2011 | HP Computers & Internet
I have a dead hp pavilion dv9500 laptop. The battery doeds not charge. It does not work with the battery out. The dc socket lights up when the charger is plugged in. The charger is ok.
This almost certainly means that the internal power converter inside the laptop's motherboard has burned out or otherwise stopped working. Unfortunately, a fix would require a replacement motherboard, as laptops do not have an internal power supply like desktops.
If the laptop is less than 1 year old, or you have any kind of extended warranty on it, it might be covered in the case of a power surge, which is the most likely culprit for damage like this. Otherwise, you will need to contact HP to see what they might charge for a replacement motherboard.
In most cases, a fix (in parts and labor) will be more expensive than simply purchasing a new laptop. It's unfortunate that this is the case, but it often is true. If you decide to contact HP about a fix, make sure that they give you an estimate BEFORE you send your laptop to them, as the costs to repair laptops can sometimes be outrageous.
If you have important data that needs to be retrieved from the computer's hard drive (which is likely fine, and all your data is probably still there unless the damage was much more catastrophic than it appears) I would recommend speaking with a local professional. They should be able to do data recovery for you for less than $100 USD.
Good luck, and hope this is helpful!
Jun 01, 2011 | HP Pavilion DV9500Z Notebook PC
Why won't my hp turn on?
The 1st thing to try is to make sure that the outlet you are plugged into has power. Try plugging in a lamp or fan or something and ensure that it powers on.
2nd some power packs have a seperate power cord from the power pack that may come loose ensure that it is plugged in tight if you have this model of power pack
3rd is to check the power pack you are using. The easiest way to do this is with a volt meter if you have one. They output in DC so ensure that you have it set to DC on the dial. If you do not have a volt meter check if there are any lights on the power pack that should light up when it is plugged in. If there are no lights on the power pack then there is not much of a way to check the power pack without a volt meter.
The last thing it could be would be the charging or power circuit of the motherboard. This would only be able to be diagnosed by a certified repair technician. If the laptop is still under warranty you will want to contact HP to have this checked.
Dec 19, 2008 | HP Computers & Internet
HP Pavillion dv6000 - dark screen, no power noise, but power lights are on
1) Turn off your laptop.  2) Remove Power supply.  3) Remove the battery and put it back again after 1 min.  4) Put power back and restart.
This should solve the porblem ! I have had it several times.
May 06, 2008 | HP Pavilion dv6000z Notebook
Help,please keep answer simple.
Clicking noises coming from a computer is generally a bad hard drive and must be replaced.
*However* the power going off may mean it is a fan that is bad and needs to be replaced.
Either way the laptop will require a replacement part, so take it to a computer repair shop and will be able to determine which it is fairly quickly.
Nov 11, 2007 | HP Pavilion ze5170 Notebook
Computers & Internet Logo
62 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
