Question about Univex SRMF20 Stand Mixer
Problem with belts on a SRMF20 mixer #1020501 cog belt and #1020502 cog belt What size belt should I use (auto parts) as I don't have easy access to original equipment immediately. Thanks for your help J-J
I have a 60 qt. Hobart Mixer and it works but I can literally grab the dough hook and stop it with my hands, when in first gear. Does anyone know what the problem could be?
If I remember from the last time I saw inside one they are belt driven. It sounds like yours is slack. There are screws on the top to remove the cover plate. I also vaguely remember a Bakelite laminate cog that has a shear pin. It has been a long time though that I saw the inside but have used them often. I am a chef, qualified in 1971 :-)
Oct 06, 2015 | Hobart Food Mixers
Disassembling the gearbox on Kenwood mixer A707
If the belt wheel is pressed onto a spindle, you need a gear puller. Do you have any pictures of this? I am trying to visualize the problem.
Nov 10, 2007 | Food Mixers
Hook straggles to turn when dough in bowel
The Legacy is an electronic mixer and the transmission does not have any gear, and it frequency convertor that works in phases 2 and 3. If the hook struggling when turns, check the transmission belt locasted at the top of the mixer, remove the cover first.
If the belt is loose, tense it with the screw on the base of the motor or replace the belt. If you can not fix it, let me know and I'll try something else.
Mar 23, 2014 | Hobart HL600 Legacy Stand Mixer
Where can i buy belt for kenwood mixer km800
take a belt and made your own home-made-belt, if you just want the machine not be shaken so much
Feb 01, 2011 | Kenwood KM800 Major Classic Stand Mixer
Blender attachment does not work
It could be the drive belts. There are three. One for the motor to the belt drive. one from belt drive to bowl mixer spindle. one from belt drive to mixer spindle. mine started to do the same thing. I ordered the belts from Bosch.
Jun 08, 2010 | Bosch 700 Watts MEK7000 Concept Series...
Need to change belts on mixer never done this before?
THE BELTS ARE NOT HARD TO CHANGE . DON'T KNOW HOW OLD THE UNIT IS BUT NEVER THE LESS THE BELTS ANE EASY TO CHANGE
Sep 27, 2009 | Hobart Food Mixers
90quartmixer gears dont have power belt torn
Is the model an M802?Did the belt break or slipping?I'm a hobart tech,let me know.
Mar 03, 2009 | Hobart H600 Stand Mixer
KitchenAid Artisan 10 speed 325Watt Mixer
Hi, The KitchenAid mixers are usually quite easy to work on if you are competent at DIY. It sounds like a gearbox fault. Gearbox parts are easy obtained for most of the models and are easy to repair.
This is a service manual for a lot of the KitchenAid mixers. Might give you an idea on how difficult it is to work on before taking the plunge.
Hope this helps
Oct 30, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Gearbox input toothed cog
I don´t think you can get a new one, you have to replace the gearbox on the machine.
Dec 02, 2007 | Kenwood KM800 Major Classic Stand Mixer
Kenwood chef
I think your toothed belt is gone and have to be replaced.
Nov 29, 2007 | Food Mixers
Univex SRMF20 Stand Mixer Logo
41 people viewed this question
Top Univex Food Mixers Experts
eyecam
Are you an Univex Food Mixer Expert? Answer questions, earn points and help others
