Question about Dell Inspiron 531s Desktop Computer
Free computer instructions on how to save a document on a usb flash drive
  • Dell Master
  • 5,471 Answers
Assuming the thumb drive is working and the computer's ports are working and has sufficient space, you use the drive like a floppy disc. Plug it in and wait until the computer recognizes it. Either edit the document in the appropriate program and then save it to the USB drive (for most File > Save As, choose location and name the file (if needed) and then click Save or OK).
Alternatively, use the File Explorer (in Windows) and navigate to the directory where the file is stored (Computer (My Computer) > Users/(user_id)/My Documents (or My Pictures or whatever folder) is the default for many applications these days). Left click on the file and drag to the USB drive on the left column (under Computer); it should default to asking if you.
You can also can right click to select move or copy. (Using two File Explorer windows (one for the hard drive's directory and one for the thumb drive) is also an option and will let you check the dates on the file(s) if you want that information and have File Explorer giving the details.)
When done, click on Safely Remove Hardware (in the taskbar) or right click and select Eject (in the File Explorer). When the computer signals that you can remove the drive, do so. (If you skip this step, you may remove the drive while data is being written and loose part of the document.)
I hope this helps.
Posted on Sep 07, 2010
I need to know how to move from a disk to a usb
If you are asking how to remove a document from the computer hard drive to the usb, all you need to do is put the usb flash drive into the usb port on the computer then find the document to move and copy to the drive letter the usb is showing, such as d:, e:. etc. Different computers have different drive letters. Depending on which operating system you are using, it may be easier to open the document you want to move and save as (using the drive letter assigned to the usb port). You will actually be saving it onto the usb just like you would have saved it on the c: drive of the computer - only a different letter for the sub. First, you will need to look to find the drive for the usb.
Oct 10, 2017 | Computers & Internet
How do I save an open office document to the usb
The same way you save other document to other USB drives oor other folders.
But when you insert the USB drive to the computer, you should see the drive in your browser. If not, the computer has trouble finding the correct driver.
First try to see the USB drive in your browser, then try saving things to it.
Feb 09, 2014 | Lexar 16Gb Jumpdrive Firefly Usb 2.0 Flash...
What file format do i save a word doc to my sandisk 2 gb
The USB flash drive is capable of storing any type of file. Save it as a word document (.doc) or anything else. However, if you use the drive on a computer that does not have WORD on it, you may not be able to open it. There are other programs that can read WORD documents: Libre Office, Corel WordPerfect and many other documents viewers.
Aug 27, 2011 | SanDisk 2GB microSD Memory Card
How to add documents on sandisk 4gb flash drive
I would assume you want to save documents to the flash drive, if this is correct, plug the flash drive to a USB port on the computer and once it is detected in My Computer (or you may get a prompt for it), just open its folder and you can copy/save files from your computer to the flash drive. NOTE: you may need to format the flash drive first using your computer if it is the first time you'll be using it.
Sep 27, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Is a flash drive good for saving documents on my computer? how would i use it if it can be used for this?
Yes , Flash drive is a good way of saving data from your computer it can also act as a back up of the data from the computer that you can access anytime, by simply connecting it to a USB port of computer.
Flash drive can be connected to a computer that has a USB port almost all computer has a a USB port including your computer.
Jan 18, 2010 | Dell Dimension 2400 PC Desktop
I want to transfer a typed page from Windows office to usb flash drive thanks
you have to save the typed page as a document. These are usually saved to "My Documents" but you can go to "File" and then click on "save as" and it will bring up a window. The default location is in "My Documents" in the top part of the window. Click the drop down box and choose your flash drive instead. Give the document a name if it doesn't already have one and hit the save key.
Oct 01, 2009 | Medion md40298 Notebook
I want to do my assignment on word.i want to save this to my u.s.b ,im not great on computers and dont no how to save or if have to do anything so my computer regodnises the flash in the first place pleze...
Check
1. Word document .doc extension (Word 97-2003-document); this way
you can access the document even on older computers.
2. Connect the Cruzer always directly to the computer for transfers.
3. USB flash drive enough free memory (e.g. pics require a lot of memory)
4. USB flash drive has memory format FAT or FAT32
5. Have a backup on your computer on a seperate partition of the hard drive on your computer; another partition than the place where "My documents" are located. (in case you should have to restore the Operating System)
See next items how to locate your flash drive on the computer.:
Windows requirements:
When there's a drive letter conflict it can happen that the flash drive is not recognized, see:
Once you can locate the drive and know if there's plenty of memory
free you can drag and drop your document from the computer to
the flash drive: the document on the computer will stay as well.
You can also right click on the document and next select copy.
Then select (left click) your flash drive, next right click and select paste in the field of the flash drive or any map on the flash drive.
Sep 21, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to save my documents to lexar 2gb jumpdrive
You can simply drag the My Documents to the drive, that will make a copy. But you could also use the backup function of Windows (simply type 'backup ' in the Windows help and follow instructions).
Jules
Mar 02, 2009 | Lexar JumpDrive Classic Portable USB Data...
I don't know a thing about it.
When you insert the flash drive into a USB port, the system will (okay, should) recognize it as a "removable" drive. It will assign a drive letter to it, which you can treat as a regular hard drive.
So, plug it in, then open My Computer, and you should see it there. Save to it, delete from it, whatever you want. If your system is not recognizing it (XP and Vista should do so, automatically), then you may have a flash drive that requires a driver (typically, SanDisk units do not).
Cheers
Nick
Dec 20, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to use usb flash drive
connect it on usb hub then scan it with anti virus, sometimes your flash disk will just pop out on your computer then it will play automatically. or or or if u want to save on your usb, just choose the file you want then save it to mycomputer-then E/your flash drive.
hope you understand. :)
Mar 27, 2008 | Computers & Internet
Dell Inspiron 531s Desktop Computer   Logo
48 people viewed this question
Alun Cox
