Question about Zenith L20V54S TV
I am working on a Zenith L20V54S LCD TV. The TV works fine with one exception. One of the channels receives audio but no video. When I tune to this one channel, I get audio, no video, and maybe 10 seconds later I get a "channel blocked" pop-up. The channel is not blocked according to the set-up menu. Thanks for your help. jw
techman
  • 3130 Answers
SOURCE: Zenith Concierge hotel tv wont work with my xbox 360
There may be a door in the front of the ste that is locked. You could take off the back and see if there are any circuit boards attached to the front of the ste and then that would show you where the door would be. Sometimes they losck the door with tabs on the inside and has to be pryed off.
Posted on Mar 21, 2008
scottyfixit
  • 186 Answers
SOURCE: Fried remote control receiver? (Zenith B32A24Z)
Invest in a long poking stick....... Either the Infrared receiver or controller it blew out. The high amount of static electricity formed and must of jumped off by the infrared receiver causing a momentary short in the circuit board. Safety's shut the tv down before frying, but damage looks to be done. It can be fixed, but only cheap if only the infrared receiver was damaged, anything else and it's going to be pricey.
Posted on Apr 23, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Zenith B27A11Z 27" TV, can't get into menu, original remote gone
Most universal or multi-brand remotes will control a TV's basic functions, but almost none will support advanced functions like menus. If the TV doesn't have a front panel menu button, the best solution is to buy a universal remote of the same brand as the TV. If you get a Zenith universal remote, it should have a menu button that will work with the TV.
Posted on Dec 14, 2008
rockitman187
  • 2559 Answers
SOURCE: cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Posted on Feb 01, 2009
TOM2-TOM2
  • 110 Answers
SOURCE: Philips Magnavox TP2784C TV always powers up to Channel 9
Unplug unit from AC outlet for 10 - mins then plug back in to AC. Turn unit on select channel 3 turn off and back on.
Posted on May 18, 2009
No TV broadcast picture. Is this a tuner problem?
yes it does seem to be a tuner problem , I also wonder what happens when you use the auto channel finder and tuner usually found in the set up section of the menu ? As well as was your TV working before and receiving input via the antennae but has now stopped working in this regard ? I also noted that attaching an analog to digital converter box worked fine , so your TV is capable of receiving a signal via that method , dose the converter box use your antennae input jack or a video jack to send the converted signal into your TV ? if it is using your antennae jack then it may not be a tuner problem .
Jul 19, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
Zenith PV4663RK Rear Projection TV - Manufactured - Mar. 1995
Are you connected to cable TV using a digital receiver? If so, your TV can only get the signal for one channel - the one you're tuned into on your receiver. A workaround is to connect the coax cable TV cable directly to your TV, as well as connecting your receiver to your TV. This will allow you to be able to change the channel on your receiver and be able to change the channel on your TV to one of the analog channels you can tune into by connecting the coax cable directly to the TV.
Jan 09, 2008 | Zenith IQB50M90W 50" Rear Projection...
Olevia 237t No Audio or Video on HD Channels
Try to connect the ROKU player to the television directly
Make sure that the internet connection to the player is from your router
Use your television remote to select the proper input to your television
Try this and check if it works.
It should work
Oct 23, 2009 | Olevia 237T 37 in. LCD TV
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
Oct 03, 2009 | Zenith Analog to Digital Audio Converter
Apr 23, 2008 | Zenith B32A24Z 32" TV
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cable channels 5 and 6
not sure on this model , but check your menu and see under the setup menu if it has a band select option or tuning band. sometimes the autoprogram may pick up the wrong band. Make sure it is set correctly. I had this where it would just make some certain channels bad.
Nov 01, 2007 | Zenith A25B33W 25" TV
Zenith wont tune channels
You must get a proper replacement remote control, once you can access the menu and find you cannot store above 13, place another post and i will help you further.
Oct 11, 2007 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Zenith L20V54S TV Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
