Question about Maytag MFC2061HES Stainless Steel French Door Refrigerator
I have an 2004 Maytag Bottom freezer with french doors. At first I heard the Ice maker making sounds in which we do not use (It's turned off and arm in the up position) Now the freezer isn't cold anymore and seems as if fridge is losing temp too. I do not have the model # with me at this time : ( can you offer some sort of help plz
5 Suggested Answers
SOURCE: Ice Maker door flapping-Contral panel flashing
the solution is to replace the High Voltage Board. It's 149.99 usually. part number is 12920710. Call me if you want one. My cell number is 516-650-6167.
Posted on Aug 04, 2007
Sea Breeze
  • 4655 Answers
SOURCE: Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
Posted on May 26, 2009
  • 1891 Answers
SOURCE: Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Posted on Apr 19, 2010
Testimonial: "Thank you. We will work on that and see what happens. "
  • 16 Answers
SOURCE: Ice maker not making ice
check the water solenoid for the ice maker on the back
Posted on Jun 11, 2010
Water will not dispense.
have you try replacing the water filter if that does not help check your water solenoid valve.
Feb 22, 2015 | Maytag (MFI2568AEW) Bottom Freezer French...
Samsung rf266aepn bottom french door ice maker arm
Simple but a pain. Unplug the refrigerator. Get out your hair dryers and start de-icing the freezer door. Slowly but surly you will get freezer open. Be gentle. Dry EVERYTHING!!! Tracks, rails.....then replace part, plug back in, restock.
Oct 12, 2013 | Samsung RF266AEPN
Maytag refrigerator stainless steel french door bottom freezer...lights flashing and ice maker opening and closing/making sound
Im thinking maybe a power surge was felt by the refrigerator.
Try unplugging from wall for a couple minutes and then plugging it in again.
Hope this resets it...
Jul 23, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Have water no ice
Make sure the ice maker is on, small white rocker switch on ice maker if applicable. Make sure the Wire arm is in the down position. Make sure the water is on.
May 07, 2011 | Maytag MFI2569VE Bottom Freezer French...
Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
We can't turn off our automatic ice maker. The instructions say to raise the handle up - well we've done that and it still comes on every five minute. We have a Maytag French Door refrigerator with the...
Are you sure you are raising the arm high enough to disarm your ice maker? Try to set it a little higher than you orignally did and that should do it for you.
We hope this helps your problem out and we hope to be able to continue to help you with all your appliance issues in the future.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Nov 06, 2009 | Maytag MFD2560HES Bottom Freezer French...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Aug 24, 2009 | Maytag MFD2560HES Bottom Freezer French...
Brand new french door maytag refrigerator makes a loud knocking sound off and on all day. Is that normal ?
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
May 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
Ice maker wont make ice
CHANGE THE FREEZER TEMP TO -2 AND THE REFRIGERATOR TEMP TO 44 AND IT WILL START MAKING ICE AGAIN
Nov 25, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFC2061HES Stainless Steel French Door Refrigerator Logo
23 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
