Question about Konica Minolta DiALTA Di183F Copier
Tiene codigo cf-033 la copiadora modelo di-450
  • 8 Answers
You have two different models listed .Well for the Di 450 _CF033 error
Description:
C0F33.
Solution:
Check to make sure that the ATDC value noted after running F8 was entered as the "set" value in the Adjust Mode. If the ATDC "set" value was correct, check the connections between the PWB-A and the ATDC.
To check the ATDC "set" value follow the procedure below:
1. Enter the Tech Rep. mode.
2. Press the stop key and then the start key
3. Select printer.
4. Select ATDC reference value. The current value should be close to 5V and the set value should be the same voltage setting as the current. If the value is found to be at "0V" the ATDC setting was not set properly when new developer was installed.
Note: When installing new developer, make sure that the toner hopper and sub hopper are empty. If not, extra toner may be added at the time the ATDC reference value is set (during F8 process). This will cause light copies. please send more feed back on di 183 problem
Posted on Sep 11, 2010
Codigos para control remoto DISH NETWORK 2 4.4 IR UHF PRO
Hola! Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. Si tiene preguntasadicionales, sientase libre de contactarme a: kimberly.escobar@dish.com
Kimberly Escobar
Social Media Representative
DISH L.L.C
Mar 01, 2014 | DISH Network IR Remote Control
Necesito programar el control remoto dish modelo 175544 20.0 IR a un tv LG
Hola, para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor comuniquese conmigo a: kimberly.escobar@dish.com
Kimberly Escobar
DISH L.L. C
Aug 26, 2013 | DISH Network IR Remote Control
NECESITO EL CODIGO DE UN TELEVISOR SANYO CON UN CONTROL REMOTO DE JVC
These are the codes for Sanyo TV: 0049 0097 0110 0004 0268 0012 0108 0180
Aug 19, 2012 | RCA Universal Remote Control
Hola tengo un mando universal total control y necesito los codigos para el mini TDT mpg me puedes enviar los codigos o alguna url que me los ponga muchas gracias
MANDO ITC MODELO H-1080E LA TELE ES DE LA MARCA HANNSPREE Y ME HACE FALTA EL CODIGO,DONDE ME LO PUEDO DESCARGAR.GRACIAS
Jun 15, 2011 | Jensen Televison & Video
Mi radio clarion DB328R tiene escrito la palabra SECURITI ,necesito saber cual es el codigo de mi radio para que me funcione como deberia,xf gracias
Generalmente el codigo de radio esta en las ultimas paginas del manual de usuario: sino, con los datos de serie y modelo podria obtenerlos en la tienda del vendedor.
Suerte.
Mar 05, 2011 | Clarion Car Audio & Video
APARECE EL CODIGO C6020 Y NO PERMITE SACAR COPIAS
El codigo C6020 significa que hubo sobrecalentamiento en el Fuser. Si Ud. es tecnico en copiadoras, cheque la resistencia del THMS, ien caso de ser 0 ohms, reemplace. De otro modo, puede que la fuente de poder esté dañada. despues de hacer reemplazo de piezas, resetee la copiadora con el codigo U163.
En caso de no tener idea de que estoy hablando, le recomiendo solicitar servicio tecnico para la computadora ya que es un problema serio en el equipo.
Dec 07, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Desconectaron la Vateria de mi carro Hinda Modelo 2000 cívica párrafo y encender la radio me PIDE EL codigo de las Naciones Unidas de 5 digitos Que no tengo, ya Que tampoco Tengo El manuel del...
Ante la ausencia del manual del propietario y de la posesion del codigo de desbloqueo, necesariamente, Usted tiene que visitar a su representante Honda, demostrandole que el vehiculo es de su propiedad, para poder obtener el codigo de desbloqueo correcto. A veces este servicio es cobrado. tenga en cuenta que este codigo es unico, y que nadie se lo puede ofrecer por Internet.
Espero que esta respuesta le sea de utilidad (recuerde calificar la ayuda).
Oct 11, 2010 | Honda Civic Cars & Trucks
Es un problema tecnico me marca f100 es de una copiadora toshiba e-studio 452 y pues necesito reestableser el servicio de esta maquina espero atiendan este problema y den solucion gracias
Tienes problemas con el disco duro de la copiadora, puedes formatearlo haber si se restablece, para eso tienes que:
1.- prender la copiadora presionando 0+8
2.- poner 690 y presionar start
3.- poner 2 y presionar set.
4.- esperar el mensaje en pantalla de reboot the machine, puede tardar hasta 5 minutos despues de ahi tu disco esta dañado y necesita reemplasarse, junto con el firmware.
5.- apaga la copiadora y vuelvela a prender.
has pruebas funcionales.
Sep 16, 2010 | Toshiba e-Studio 350 Copier
No enciende la maquina
¿Usted tiene el poder pero su copiadora no trabaja? ¿Esto es una copiadora o una impresora? Por favor dígame la marca registrada de la copiadora y el número modelo. Gracias.
Aug 18, 2008 | Office Equipment & Supplies
Konica Minolta DiALTA Di183F Copier Logo
659 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
