T0shiba model 50hm66 replacedlamp that was brokewith a y67lmp /75007091 ushioe23dc120/150wbare lamp set will go of lampstays litt till u turn it off
  • 3 more comments
  • dlsvideo Sep 08, 2010
    tn the above information abought50hm66 lamp will not go off till you unplug the set then replugset will do the same thinglamp will stay on that is the best i can tell you
  • dlsvideo Sep 10, 2010
    i posted that the lamp would not go off the tv sound and picture is ok lamp stays lit whenyou turn set off e
  • dlsvideo Sep 13, 2010
    i added acoment about three days ago did not git any feedback from ladywinnon toshiba that lamp did not go off tv sound an pic goes off y67lmpstays litt hafe to unplug tv to git lamp off plug unit back in and it repeats over set off lamp stays litt
  • 5,138 Answers
Replacement Lamp for the 50hm66/ Lamp Y-66
Part number is 75007110 Mats Electronics has Lamps fr $99.00
1-800-628-1118 . Is all Fans running Lamp Fan.Ballast Fan, also go back and recheck everything to make sure nothing was lefted unpluged. Does the TV work at all? Sound? Picture?
Posted on Sep 08, 2010
  • 10,865 Answers
Hello. Please restate your problem with a few more details as I would really like to assist you. thanks, J.
50hm66
Some possible reasons include: New lamp is generic and or has a issue----excessive dust or dirt inside the unit on fans etc.
Some of these units had a feature in the menu for quick on where lamp is lit at low level all the time---this shortens the life of the lamp etc
If you did not have this issue before lamp replaced I would suspect a generic cheap bulb may have been used instead of the Toshiba cartridge / lamp combo which costs more.
With the quick on if the set has it normal time is 20 seconds for screen to light----set WILL DETECT IF LAMP IS NOT COMING UP FAST ENOUGH OR BRIGHT ENOUGH.
Generic lamps (cheap) will never be as bright or last a long as a OEM lamp unit.
Just some thoughts based on your question.
Aug 28, 2012 | Toshiba 50HM66 52" Television
Hello, I am having difficulties with. TOSHIBA Y67-LMP / 75008204 / 75007091 The lamp on our tv went out a couple of months or so ago. I ordered another from ebay. It worked for 2 weeks then...
If you have a set like 50hm66 or something near, it could be your ballast going bad, but you would need to do alot of checks to find out what.
Jan 15, 2011 | Toshiba Televison & Video
I recently replaced my lamp light on my 50HM66 the tv worked great for about a week then while watching tv my screen went black and lost sound. When I turn on my tv it begins to shut off and on numerous...
Hey it sounds like you may have one of two problems here one you may have a bad lamp issue or two a bad ballast board I think at this point it will be a ballast it might be to weak to turn on the lamp or it is burning out the lamps to soon here is a link about Toshiba will change the way you think about this BRAND
http://www.avrev.com/home-theater-rear-projection-hdtvs/dlp-rear-projection-hdtvs/toshiba-ordered-to-pay-out-in-dlp-lamp-lawsuit.html
PLEASE RATE THIS AS I DO THIS FOR FREE !!!!
Oct 04, 2010 | Toshiba 50HM66 52" Television
My 50hm66 will turn on,picture comes on for about 10 seconds and then the tv turns off.After it turns off flashing red led on front of tv. What would cause this?thanks jim
I had similar problem with my 50HM66 , except it would stay on for at least a few minutes. I cleaned and vaccuumed (with lamp removed) as best I could, I think it's an over heating issue. My TV is 3 yrs old, have replaced lamp once, it did it with either lamp. When I put a fan to the right of the TV so it's blowing behind it, my TV doesn't shut off. Something to try...
Sep 22, 2010 | Toshiba 50HM66 52" Television
I just replaced the lamp in my tv, it will work fine for 10-15 minutes, after that the picture will start to flicker and then just go out completley and th lamp light will blink on the tv set, what could...
My 50HM66 did the same thing. Try putting a fan to the side of the tv so it blows cool air around the back. I also removed lamp and vaccuumed as best I could. I think this is an overheating issue with the tv.
Sep 03, 2010 | Toshiba 50HM66 52" Television
I have the 50hm66 tv, replaced the main power supply board, and then the aux. power suppy board, still no lamp (lamp is good), 15 yellow blinks What you think ???
U hear alot of clickings,few mins tv is on?The board call the Ballast board is dead.This Ballast board help to ignite the projection lamp.
Aug 13, 2010 | Toshiba 50HM66 52" Television
Is Y67 the lamp I need for model 57H82 & how do I get to it?
Y67-LMP-75007091 Call FOX Lamps 129.00 Make sure you give them correct Model number its on the back of your TV 1-800-227-5369 or Try Mats 1-800-628-1118
Dec 03, 2009 | Toshiba 57H82 57" Rear Projection...
Adjust convergence on toshiba 50hm66 projection tv
can't adjust convergence on this set most likely bad light engine very expensive repair.
Aug 07, 2009 | Toshiba 50HM66 52" Television
Replaced lamp on my toshiba 50hm66 and still wont turn on
hello i'm not sure if i'm right but when you install these lamps you rght have reset the lamp counter
shaun
Mar 21, 2009 | Toshiba 50HM66 52" Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
