Question about Intel Motherboard
There is power but nothing else (video card is tested and works). I cannot get the bios
    President:
  • 1,851 Answers
Remove everything but the memory and VGA. Sometimes not regognized / wrong settings at the hard disks / dvds cause the bis to froze. Start up without drives and check the settings.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 07, 2010
Asrock g31mgs no power
You need to set the Bios to default to your video card and not your on-board video or disable the on-board video in the Bios..
Jun 25, 2012 | Computers & Internet
I purchase a new Sapphire HD 5830 Extreem card recently and match it with my old ASRock Wolfdale 1333-D667 motherboard. I just can't seems to get any display on my LCD monior. The PC is able to start...
dude you just need to update the bios !!!! to latest 1.53.version... on the official site of motherboard are the steps on how to do it!! Here is the link to the version http://europe.asrock.com/downloadsite/bios/775/Wolfdale1333-D667(1.53).zip and here is the link of the asrock page http://www.asrock.com/mb/Intel/Wolfdale1333-D667/?cat=Download&os=All
Jul 11, 2011 | Sapphire RADEON Xtreme HD 5830 800MHZ 4GHZ...
I have a acer aspire t660 pc. i buy a sapphire hd 5670 512mb videocard, but my pc dont reconise it. i test this videocard on another pc and it works. i try to change in bios the settings but nothing...
Make sure you set the primary graphics in the bios to pic-e and you will likely have to upgrade your power supply as this card requires at least a 400 watt you pc came with a 285 watt not near enough power for this video card and could be your problem
Feb 08, 2011 | Sapphire RADEON HD 5670, (512 MB) Video...
Computer turns on but nothing is dispalyed
You say the PC turns on... does this mean that it goes through POST (u hear those beeps etc)? This means that you have power but no apparently no video.
Test for VIDEO in the most basic form
Power up PC and see if u can access the BIOS (F2). If u can access the BIOS then it means your video card works.
If u cannot access the BIOS, it means you have a more severe problem and may have to change the system board to resolve it.
PLEASE NOTE
If you are actually getting NO POWER (meaning that there is no post and no indication of power) then it is a different story altogether. U're looking at a new power supply or new system board if it's integrated on the board and cannot be replaced.
Mar 15, 2010 | Acer Aspire One Netbook 8.9" Notebook
Dimension 4400 nothing happens when i power up cd doesn't read hard drive doesn't turn the only thing it does is startup beep
The bios is configured to boot to CD? Monitor turns on, and you can see the Bios? HardDrive has an OS installed? There may also be a ram / motherboard issue. I would also test the video card. But I would start by Unplugging the power cord, and reseting the Bios. If you know which jumper, use it, if not just remove and after about thirty seconds re-install the onboard QUATER battery. After this boot to Bios, check all the Boot - Drive parameters and try to boot up. If that fails continue with the Ram Check, the Motherboard, and the HardDrive, and the Video Card. Hope this helps.
Dec 17, 2009 | Dell Computers & Internet
I have 1Gb memory in A1 & A2 Power is
check your ram modules and also check if your video cards fans are running right. If both are ok then try clearing the bios it should work out
Nov 17, 2009 | ASUS NCT-D (90MSV430G0UAY) Motherboard
I just installed a new sapphire radeon atlantis 9600 pro video card 256GB ... everything installed and ran well until it restarted...now the monitor will not receive signal
check the bios and make sure that the onbord video is disabled, pull battery off the motherboard and reset everything if nothing else works, Be sure to plug monitor into the onboard video card so u can access the bios, also check that cable is snug at both ends(i know silly but you would be amazed) if stilll nothing fallback on other videocard and test new card in another computer, was the videocard seated snugly and tightened down good?
Jul 15, 2009 | ASUS P4S800-MX Motherboard
I change my video card settings in Bios to AGP, after that, i already installed my video card, but no display appeared, ican't restore my video card setting to previous settings because my monitor has no...
if you still have old video card remove the new one and replace with old one
change setting back in bios
then reinstall new card and instead of changing through bios just start computer it should automatically change settings for you
please let me know
May 03, 2009 | Computers & Internet
Won't boot
You will need to flash the graphics bios of you comp. Put the CD that you got along with the Card and reboot your computer and then follow the onscreen instructions to flash it.
Let me know if you need more help!
Regards,
Sai.
Sep 26, 2008 | Gateway 510 X (10272197) PC Desktop
Intel Motherboard Logo
23 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
