I have a 32inch lcd 450..It has sound problem.I sounds like "heart" beating or ticking sound . How do I fix this ?
  • 2 more comments
  • smillar May 14, 2008
    It's a Samsung 32 inch LCD 450..I will check the cables and connections..It's only 4 weeks old
    yes that is correct.
    should I take it back to the store
    next time I will buy a sony
  • 13,433 Answers
First check your cables and connections.
Posted on May 14, 2008
  • Ekse May 14, 2008
    also what is the brand and model of your television?
  • 3,037 Answers
The tv works otherwise with this ticking sound correct?
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri May 14, 2008
    Well, if it is brand new, then yes take it back, most likely it is a blown circuit or some shorted part inside. If you even try taking it apart, the warranty will most likely be voided. If you have the option of taking it back, always do so. It will be much easier on you that way.
    Good luck with the next tv.
  • Benjamin Patri
    I'm sure that you must have just got a defective model, good luck on your hunt for a new tv may I suggest the Element 32in lcd HDTV from Circuit City for only 479.99?
    Great Deal I think
  • Benjamin Patri
    Benjamin Patri May 19, 2008
    Please don't forget to give me some feedback by rating my solution.
    Have a Great Day!
Which is the best portable fetal Doppler?
One of the best and latest portable fetal Doppler that can be used to hear the heart beats of the unborn baby is an NHNCIO fetal heart Doppler.
Here are some of the best features of this device:
a. Largely backlit LCD display
b. Independent probe with coiled cable
c. Pocket sized unit designed for travel
d. Three different modes to choose from
e. Real time display, 10 beat average and an 8 beat average
f. Integrated amplifier
g. Can be connected to an external device to record the sounds
To get more more information, you can visit Fetal Doppler Reviews.
Jul 29, 2017 | Best Computers & Internet
Blinking heart beat led blinking
When the following situations, you need to replace the LCD screen:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
http://www.lcdinverter.info/compaq-presario-cq40533tx-lcd-inverter-p-2632.html
May 24, 2013 | HEWLETT-PACKARD Hewlett Packard HP...
Bought an 32inch LCD HDTV DVD Combo not even a year ago---there is picture but no sound---can't turn up sound with remote or even turn up sound manually--any ideas?i
Good day!!!
That problem is usually cause of low reception if you are using aerial antenna,if your are using cable or digital signal check your wiring and the worst is you have defective audio IC..
I will teach how to determine the exact trouble just click this link LCD HDTV ASSUMED TO FIX and click "get service"..
Thanks for using fixya...
Nov 03, 2011 | RCA L32HD32D 32 in. LCD HDTV
When I took my blood preasure there's a heartbeat sign next to my pulse reading. What does that mean
It shows your heart is till beating and the LCD readout should tell you, your heart rate. Some monitors will also indicate if the heart beat is regular or irregular.
Feb 13, 2011 | Health & Beauty
Mitsubishi ts-5545, Black screen and Heart beat
A couple of things:
1) Either a bad power supply or a flyback 'supplies the high voltage to the 3 CRT's' .
2) The HOT 'High Output Transistor' is gone bad or the leads 'solder joints' have cracked and are not making a good connection.
time to get it into the shop or have a tech come to your residence to look at it.
Good possibility of getting it fixed.
A/V Media Guy
Nov 22, 2009 | Mitsubishi TS-5545 55" Rear Projection...
SAMSUNG LCD TV - smell came up
Take out the back panel and smell to trace what part is burned. Then check the high voltage circuit near the 120 volts. After the transformer, should be 380 volts AC. After the ratifiers, should be 390 volts DC - by checking at the capacitor as Samsung uses 100 uf at 450 volts. If not, change the capacitor to a higher rating like 350 uf at 400 to 450 volts.
Nov 16, 2017 | Samsung LN-R408D 40 in. LCD HDTV
Big screen no picture and makes heart beat noise?
can be a faulty mains board, does the sound still work? if not, can be mains board, and at last if there is a continuous clicking sound it a faulty power supply.
hope that help
pls rate me!
Mar 21, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Polar F6
It sounds like most of you have the heart rate set to display in % of max heart rate. Most Polar products have the option of heart rate in BPM(beats per minute) or percentage of max.
If you look at the display during the exercise, you will see a % icon. You can turn it off in by hitting the back button and go down to HR view settings.
Hope this helps.
Chris @ Polar USA
Aug 02, 2008 | Polar F6 Wrist Watch
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
