Question about Health & Beauty
We have a Wheelchairs of Kansas Overlander model with a joystick controller. It’s stuck in 5th gear and we can’t get it back down to 1st or 2nd gear. Will this condition likely require a new controller unit or can the unit possibly be repaired?
  • 692 Answers
Shantel I can't help with this problem but you can call the company @ 1-800-537-6454 and see if they can give you help with your problem Good Luck and hope this helps you
Posted on Sep 09, 2010
Gear stuck in 5th, shifter works fine. Cable fine, put in 4th shifter starts rattling, stays in 5th (1st &2nd) car is stuck. Internal it looks like, but hope I'm wrong. Please tell me
Sounds internal to me. Fifth gear bearing locked up. I assume it is manual(unless the bearing has welded itself to the shaft and case)? These aren't hard to rebuild. Automatics are a bit trickier. Either of them have to come out.
Oct 25, 2014 | Cars & Trucks
5th gear went out yesterday when u put it in 5th its 3rd gear. Then today reverse 1st and 2nd went out. Reverse 1st and 5th is 3rd and 2nd and 4th both is 4th gear
time to put a new tranny in that jet most of the time it costs to much to repair it then replace it i have done may tranny rebuilds and replacements to me i would just tell you to replace it at least you will get a better warrentee and stuff
Feb 27, 2011 | 1988 Volkswagen Jetta
How do i on a motorcycle go to first gear from 5th
hi, if when you start your bike you press the gear lever down to go to 1st from neutral and then pull it back up to go to 2nd,3rd,4th and 5th then the only way to get back into first gear is to press the gear lever down 4 times to get it back into 1st gear their is no quicker way to do this you have to work your way back down the gears.
if your coming to a stop quick then just pull the clutch in and keep pushing the lever down until it dont push down any further it will only go down 1 gear at a time so you will need to push it down 4 times but you dont need to count you can just keep pressing it down the gears until it dont go down any more then you know this is first, you need to keep the clutch in when doing this.
how ever if your slowing down is more gradual then what you can do is go from 5th down to 4th then let engine slow the bike down then when the revs drop down change down to 3rd and so on until you get ot 1st gear.
if your coming to a stop quick say at lights or junction then if the bike is in 5th gear then you can change down the gears once the bike has stopped just hold the clutch in when you stop and keep tapping the gear lever down until you feel that its not going down any more gears this way you know its in 1st without having to cound down the gears, their id no quicker way of going down the gears to get to 1st.
i hope i have read your question right and gave you the answer you was looking for if i got the question wrong then please explain then i can assist you further ok
May 23, 2010 | 2005 Yamaha Xv 250 Virago S
What is the function of 1st,2nd,3rd,4th,5th gear?
the function of the gears are to transfer and convert energy created by the engine into momentum
Feb 12, 2010 | 2003 Toyota Corolla
What different gear box can fit honda integra xsi vtec 1600cc b16a? i want to change my gear box ,and i want to know what exactly other gear box can fit my car?thanks its a integra bot the product can show...
J1/S1 Found in: Integra XSI/RSI (DA6) Type: Cable 1st: 3.230 2nd: 2.105 3rd: 1.458 4th: 1.107 5th: 0.848 R: 3.000 FD: 4.400 Y1 Found in: CRX/Civic (optional LSD) Type: Cable 1st: 3.166 2nd: 2.052 3rd: 1.416 4th: 1.103 5th: 0.870 R: 3.000 FD: 4.266 YS1 Found in: Integra 92-93 XSI/RSI (DA6, DA9) Type: Cable 1st: 3.307 2nd: 2.105 3rd: 1.458 4th: 1.107 5th: 0.880 R: 3.000 FD: 4.400 S80 Found in: Integra Type R 98+ (LSD) Type: Hydraulic 1st: 3.230 2nd: 2.105 3rd: 1.458 4th: 1.034 5th: 0.787 R: 3.000 FD: 4.785 S80/Y80 Found in: JDM SiR-G (optional LSD) Type: Hydraulic 1st: 3.230 2nd: 1.900 3rd: 1.360 4th: 1.034 5th: 0.787 R: 3.000 FD: 4.400 Y21/Y80/S80/S4C Found in: JDM 96-97 Integra R(LSD) JDM Civic R [EK9](LSD) JDM Civic SiR [EK4, EG6] JDM CR-X DEL SOL SIR (EG2)(optional LSD) USDM DEL SOL VTEC (EG2)(OPTIONAL LSD) Type: Hydraulic 1st: 3.230 2nd: 2.105 3rd: 1.458 4th: 1.107 5th: 0.848 R: 3.000 FD: 4.400
Jun 08, 2009 | 1990 Honda CRX
Gears change without a command from the driver.
There is a vacuum controlled selector valve on the selespeed alfa's it tricky to get at and expensive to replace. Have it sent to an alfa specialist or main dealer and they ll sort it
May 05, 2009 | 2000 Alfa Romeo 156
1992 ford explorer manuel transmission getting it into gear
Try putting it in 2nd, then 1st, if that works, sounds like you clutch is bad or defective. 1st gear has no syncro to slow the gears down, 2nd, 3rd, 4th, 5th do.
Mar 28, 2009 | 1992 Ford Explorer
Health & Beauty Logo
47 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
