Question about Refrigerators
It has started to spread around the ice water area on the front. I have tried to clean it off, but it not coming off. It has gotten bigger and is growing around the ice/water area. It is about five years old and a Samsung model RS 2630 WW
  • dojay1 Sep 07, 2010
    Here is the problem my refrigerator is rusting and bubbling around the ice and water area, how do I get rid of it and stop it from coming back?
    Please help me with the problem of rusting and bubbling around the front of my refrigerator. It is growing around the ice and water area. I have tried scrubbing it off, but it is not moving. I need to get rid of it and prevent it from coming back.
  • Refrigerators Master
  • 3,083 Answers
I found this advice on the net:
You do not want to allow the samsung refrigerator water filter to run out of the ability to clean you water and then allow it to just sit there. If the filter is not replaced on a regular basis then you are not drinking water that has been cleaned properly.
Read more: http://www.articlesnatch.com/Article/Looking-For-Samsung-Refrigerator-Water-Filter/1247218#ixzz0ys1skTRX
Under Creative Commons License: Attribution No Derivatives I read on another blog that you can clean the mold with a bleach solution to remove it. Check for a filter or consider putting an inline filter on. You might check with an appliance repair shop- they usually know the best fixes and most efficient filters since they deal with them all the time. Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 07, 2010
    Brigadier General:
  • 3,917 Answers
Hi
Since you are not precise to your query,it is difficult to understand your problem,but you can check this link to have an general over view to the problems related to a refrigerator:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Mold growing around ice dispenser area. Cant figure out how to get to the mold .
Pull ice maker out and clean it. Then make sure you have a fresh water filter on water supply. Mold in the freezer is uncommon if its truly freezing inside. You have dirty water coming in.
Oct 13, 2013 | GALAXY Microsystems 25.4 cu. ft....
Whirlpool ice dispenser not working
It could be clogged. Without more info its rather hard to answer. Depending on where you water comes in, the line could be kinked or it could be loose. If no water leaking probably not loose. More commonly the line going from refrigerator to water coming into it is kinked or the line is clogged. Could also be clogged where ice comes out, especially if you are getting water but no ice. Then empty all the ice from the holding box, then clean any ice off that has built up around the ice lever area. Hope this help, Anthony
Jun 11, 2013 | Refrigerators
Ice maker water line comes loose when water turns on
Sounds like your terminal connections on the water valve have gotten reversed. Try switching them..Also you may need new water valve..
Aug 03, 2017 | Refrigerators
My ice cubes are not solid and very thin I have had a lot of repairs for m;y ice makers. One time a tech told me the water leading to ice maker is no good. Is there anything we can do to solve thin ice...
HI.CHECK FOR WATER SUPPLY VALVE WATER PRESSURE COMMING INTO THE UNIT,AND REFRIG SELENOID VALVE,IF THE PRESSURE IS OK ,REPLACED THE ICE MAKER,,ALSO CHECK FILTER AND WATER TUBE FOR WATER LEAKS..
Jul 05, 2011 | Sub-Zero 650 / O Bottom Freezer...
Ice maker stopped working
I would first check around the condensing area for lint and dust buildup and clean that up. Just doing so can sometimes get the ice maker cold enough to start producing ice. Their are 2 components that are responsible for ice production. The ice maker and the water valve. As the ice maker dumps a batch of ice near the end of that harvest cycle the ice maker powers up the water valve for 7and a half seconds. How. A probe rubs on a copper plate mounted on the inside of the main gear. Here is how she works: The ice mold thermostat gets down to around 28f. This makes it close contacts and power up the mold heater and the motor. As the ice loosens up and moves a bit you hear a click. That click kills power to the ice mold heater. The motor continues on around to dump the ice. After the ice goes home to bucketsville the copper plate rubs against the water solenoid probe and water is sent up the backsides of the icebox to the ice mold for 7.5 seconds. If you are careful you can remove that wheel and clean that plate. A simple test and a manual HERE
Aug 18, 2010 | Whirlpool Refrigerators
Will not release ice and makes crushed ice, even when on cubed.
I believe in your case the ice maker part number WR30X10093 being electronic with the control board in the front is the problem. I think the control board behind the front cover of the ice maker may have corrosion and causing the ice maker to malfunction. You can try disconnecting the set of wires to the coil on the water control valve and see if the water stops or turn off the ice maker first and try disconnecting the coil wires later. It has to be the control board or the water control valve part number WR57X10032
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Have a hotpoint side by side with water and ice in the door....and you can get ice but no water....we put in a new filter but no water will come out,,,,,help...thank you
Shawn- I had the same problem. Take a hair dryer and blow on the inside of the freezer door behind the water and ice dispenser. The water lines freeze up occasionally. Heat it for about ten minutes, spread the heat around so it doesn't melt anything. When you are done, let it stand for about five minutes before you try to get water out of the dispenser. I hope this works for you. Good luck!!!
Oct 03, 2009 | Hotpoint HSS25GFP Side by Side...
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice dispenser has black mold around area that ice comes out
shut down unit press for ice the door will open wipe with warm water
Apr 07, 2009 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
