Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Find out where hoses go - Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
  • staceyadams1 Sep 12, 2010
    false advertising. yall said this was free. should have known there is nothing free
    Scholar:
  • 71 Answers
Typical routing:
Posted on Sep 25, 2010
I need a Simpson EZI SET dishwasher inlet hose. I have been sent one but it is too short
take the hose along to a hose making shop ( any hydraulic hose manufacturer) and have a hose made to your length
or get your old hose , cut off the ends and use the fittings in a quality hose from your hardware shop
use hose clamps to fix the hoses back on the ends
Oct 20, 2016 | Vacuums
Where is the a/c expansion valve located on 2006 range rovrer
1 - Radiator
2 - Thermostat housing
3 - Radiator bottom hose
4 - Viscous fan
5 - Water pump
6 - Radiator top hose
7 - Heater return hose
8 - Coolant supply hose
9 - By-pass hose
10 - Radiator bleed (purge) hose
11 - Bleed (purge) hose, thermostat housing
12 - 'Y' piece ejector
13 - Expansion tank
14 - Heater rail
15 - Heater unit
16 - Heater feed hose
17 - Intercooler
18 - Air cleaner
19 - Air feed hose
20 - Turbocharger
21 - Charge air supply hose
22 - Cooled charge air supply hose
23 - Exhaust manifold
24 - Engine oil cooler
25 - Feed pipe, engine oil cooler
26 - Return pipe, engine oil cooler
27 - Oil filter
Aug 22, 2016 | 2006 Land Rover Range Rover
How do replace radiator hose
As car repairs go, a radiator hose is one of the easier jobs.
Get a replacement hose.
Wait for the engine to be cold.
Loosen the hose clamps at each end of the hose.
Use a heavy screwdriver if needed to loosen the hose from the radiator and engine. Pull the hose off both ends.
Put new hose on, with the clamps. Tighten the clamps.
Fill the radiator with coolant as needed.
done.
Oct 01, 2015 | Cars & Trucks
Can the hose in the retractable carrier be replaced? How do I do it?
You can replace that hose by fully extending it and locking the reel. At that point you should be able to unscrew the hose from its connector. A replacement hose can be screwed on in its place.
One alternative, if the reel's hose connector isn't inside the spool area, would be to just cut off the hose at the break, then buy a replacement hose end (with barb fitting to match your hose) and a small stainless-steel hose clamp. They work really well when you get one that's correctly sized for your hose. They're hazardous out at the "business end" of the hose, though - they can cut your hands.
Aug 04, 2014 | Toolshopusa Retractable 25' Air Hose
Hose is connected to dispose water but bucket fills up
First check that the opening from bucket to hose is clear of obstructions. If you used a washing machine hose and the filter screen is still in the end of the hose, then replace the screen with an ordinary hose gasket.
A gel-like growth can develop in the drain hose. Drain the bucket. Remove the hose and connect it to an outdoor faucet to flush the hose. Reconnect the hose using an ordinary hose gasket.
Oct 05, 2011 | Kenmore 54501 Dehumidifier
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
The hose on my accuspray turbine Hvlp system is collapsing once it gets hot. Do hoses wear out like this, and can I replace re hose with a standard garden hose, or do I need to buy an accuspray hose?...
The hose supplied by Accuspray does soften as it warms up but should not be collapsing. Most hvlp turbine system manufacturers supply a hose with a helix reinforced hose that will not collapse.
The majority of hoses for hvlp systems are 3/4" inside diameter hose like the Accuspray hose and will work with your system.
The fittings will work with any 3/4" garden hose. Problem with using garden hose is that the cheap ones will collapse and kink and the quality ones will be heavy.
May 31, 2011 | Garden
How to connect hose?
which hose the drain hose or the two water hoses the drain hose connects in the back of your machine the two water filler hoses screw on to the two inlets on the water valve also in back of your machine notice one says h for hot and the other says c for cold if these arent the hoses your talking about plz message back cuz theres also pump hose and a pressure switch hose but u havent specified exactly which hose
Aug 09, 2010 | Maytag Washing Machines
No heat on 2008 sienna, replace t-stat. one rad hose and one heater hose hot. other rad hose & heater hose cool
If your top rad. hose is cool and the engine is smoking hot, it probably is a blown head gasket. What does you temp gauge read ?
Feb 01, 2010 | 2008 Toyota Sienna
How to extend the drain hose Siemens SL34A006UC/22 Dishwasher
get another hose same diamiter and two hose clamps and a splice nipple from hardware store, cut hose to lenght with some extra insert nipple into both hoses and clamp with hose clamps make sure you get them tight.. use a metal nipple as a plastic one may crack when you clamp hoses
Dec 13, 2009 | Siemens Dishwashers
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
21 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
