Question about Canon CanoScan 8600F Flatbed Scanner
I downloaded a net program, and it screwed up my visual programs (ACDSee, Photoshop). I deleted the old programs and downloaded new versions so they now work). But now my scanner will not scan but says "unable to slect Twain Source" when I try. How can I fix this problem? I have a Canon 8600F scanner.
  • Canon Master
  • 3,083 Answers
If you're running XP or higher, and not too much time has expired since you installed the net program, your easiest bet is to restore your computer to a date earlier than the installation. Restoring doesn't lose any of your files, but it restores your registry and it's settings to the previous states, and that may restore your scanner.
The Twain settings plug-in allows preset scanner profiles to be sent to your scanner. This removes the need for the operator to use the twain user interface. Refer to this web blog for more information:
http://www.oimaging.co.uk/scantopdf-plugins-twainsettings.html
I've seen it as an option in software, but you may have to reinstall your driver for the scanner in the control panel options.
This can be tricky stuff- a very competent friend of mine spent 12 hours before he got it working, but that was a few years ago, and it's supposed to be more automatic and easier now, and it is, until a problem like this crops up.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 07, 2010
Acdsee 17
If you only tried importing to the program straight from the camera, you could try to import the pictures, using a card reader or by copying the files to the computer before importing into the program.
In addition to the basic JPG, BMP, GIF, etc. formats ACDSee 17 should support the following RAW formats:
  • CRW Canon
  • CR2 Canon
  • cRAV Sony
  • DCR Kodak
  • ERF Epson
  • HDR Creo
  • MRW Konica Minolta
  • NEF Nikon
  • ORF Olympus
  • PEF Pentax
  • RAF Fujifilm
  • RAW Casio, Contax, Leica, Panasonic, Pentax
  • RWL Leica
  • sRAW Canon
  • SRW Samsung
If you have purchased the product you can consult:
  • ACDSee 17 Online help
  • ACDSee 17 User guide
  • Official support
The Online help is at:
help acdsystems com
The User Guide in PDF format can be downloaded from:
http://help.acdsystems.com/en/acdsee-17/acdsee-17.pdf
The Customer support can be contacted at:
https://acdsystems.desk.com/customer/en/portal/emails/new
Aug 30, 2014 | Nikon COOLPIX Cameras
I downloaded the latest version of mywinlocker, unistalled the old version, but the new version won't install: I get error messages. How to access data in ild locker?
install the old Version again.yhan get the free Version of iobit uninstaller and uninstall the program,than make a powerfull scan with the same program and delet the rest.
try re-install the program.You have to be sure that your Computer have the minimum requirements for the program.Good luck ;-)
Oct 01, 2013 | Computers & Internet
0xc000007b
90 percent of 0xc0000135 error in XP is caused by .net framework. Either you have very old version of .net in your pc or you may not have it.
Finding whether your pc have .net framework or not, and what is the version is easy. Go to the website http://fxerror.com and download a small free tool which instantly show you which version is installed in your pc. Install the latest version (3.5) from microsoft download center.
If your problem still not solved then your registry have to be cleaned. You will also get a free tool to clean your pc's registry from the above website
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
net framework
http://download.cnet.com/microsoft-net-framework/3000-18513_4-47206.html
hope this helps
Sep 04, 2012 | Asrock P4I45GV R5 Motherboard
How to try the visual basic 6.0 what website
Hey
Download the latest version here
Inside the new version should be the option to work under the same conditions as visual basic 6 (without .net and other components).
Look for preferences or options
Hope this helps
-Ryan
Mar 05, 2011 | Microsoft Visual Basic 6.0 for PC
I downloaded a net program that screwed up all my visual programs (photoshop, ACDSee). I removed the old programs and downloaded replacements. But when I tried to use the scanner it said, "Unable to select...
Most likely you removed the driver or it was corrupted when you had the other problems. TWAIN is the standard for the driver that lets the hardware talk to software for this scanner. (Some newer scanners use WIA which is a Windows (Microsoft) protocol.)
To get the scanner to work, uninstall the current driver and unplug the scanner's data cable. Go to the Canon support page and download the driver and software (Toolbox if you want it) for your OS: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_8600f#DriversAndSoftware . Then plug in the scanner.
I hope this helps.
Sep 07, 2010 | Canon CanoScan 8600F Flatbed Scanner
What is the .net framework?
When a program is written is one of the visual programming languages (ie Visual Basic .net etc) it relies on a series of libraries etc. to provide the structure for it. The .net framework is a microsoft item that is required for all visual basic programs. It had a different name in the old VB6 (basically just a dll file that was usually installed by the program without you knowing) but for the layperson it's all the same.
A little bit more information is available here(As well as download):
Microsoft - http://www.microsoft.com/net/
Windows 7 and Vista generally have the framework pre-installed.
If this solution helps you, please rate it for me.
Cheers,
Jason
Jun 29, 2010 | Microsoft Computers & Internet
I recorded many pictures on floppy disc when I was using AOL. Now using a different service and I cannot view the images. How can I uncompress the images ?
You can use an Older Version of Iinternet Explorer to Open the .ART files, and then Save them As BMP or JPEGS.
Here is a Site which has a free Download of a Standalone IE browser.
http://tredosoft.com/Multiple_IE
it supports installing older versions such as IE3 and IE4.
The New version of IE disable .ART support as it has been classified as a potential security risk.
or you can purchase a product such as ACDSEE
http://store.acdsee.com/
Oct 12, 2009 | Computers & Internet
I am looking for Visual C# (for 2003)
The cheapest solution is to download the express edition Visual Studio 2008 free from
http://www.microsoft.com/Express/Download/
It is free, it is almost the complete version, you can use it commercially and if necessary it allows you to select the version of the .net frame work you wish to develop for
Sep 08, 2009 | Microsoft Visual Studio .NET Professional ...
How can i download visual basic 6 soft ware freely
Dear friend take a look to these links, I hope they help you:
http://www.youtube.com/watch?v=y4F_rPu0ddU
(Through this video you'll learn how to download VB 6.0 free)
http://www.developers.net/tsearch?searchkeys=visual+basic+6+free+download
You can aslo download Express version of VB via this link:
http://en.kioskea.net/telecharger/telecharger-104-visual-basic-express-edition
Good luck
Feb 24, 2009 | Microsoft Visual Basic 6.0 for PC
Canon CanoScan  8600F Flatbed Scanner Logo
old marine
old marine
