Question about D-Link AirPlus DI-524 Wireless Router
I lost the security key to access the internet
    President:
  • 1,851 Answers
I assume that you mean the Wi-Fi key. Log in at the router's settings page, locate the Wireless (or Wi-Fi) section. At the security part is the code you asked for.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 07, 2010
Dsi tryin to put internet using home pc as access point it says i have security key wrong
When you are searching for the access point on the DSI, make sure you select the correct one as you might pick up a few other access points that will be nearby. Also network keys have a number of letters and numbers in them, make sure you enter it correctly try using block capitals if lower case does not work. Another thing you could do is take the security key of your wireless access point (other people could access the internet using your access point). To take the security key off, just go on your computer and open up an internet browser and type in your IP address into the address bar and enter it. If you are not sure what you IP address is then go to the following website: www.whatismyip.com. At the top of the page you should see your IP address. Type it into the address bar or copy and paste it into the address bar and enter it. When you get to the page you should be able to find the option to remove the security key.
Sep 17, 2011 | Nintendo DS Lite Console
Tip
Where can I find the WEP key on my router? Router security key, router password
If you have a wireless router at home you will need to have a WEP key setup on your router. WEP stands for "Wired Equivalent Privacy" and WEP is a security protocol used to secure wireless networks. When you setup a router for wireless, you normally specify a key(password) so anyone that wishes to join your network has to enter the key. You normally set the WEP key during the router setup phase. You may have set it up and forgot it, or want to reset it. In this article I will go over the steps to find out the WEP key or change it. Your router may use a different security protocol than WEP so don't worry, you still need a KEY in order to access the network.
-On most routers(reference your user manual) you can access the router configuration page by going to the gateway address. The gateway address is the IP address assigned to your router. In a lot of the cases, this address is 192.168.1.1 but depends on your router.
There are a couple of ways to find out this IP address.
-Reference your router manual
-In Microsoft Windows, go to Start > Run and in the run box type "cmd" or "command". A black DOS windows should open. In this window, type "ipconfig /all". Look near the top and you should see a "gateway address" item. This number is the ip address of your router.
Once you know your gateway address, open up your internet browser as if you were going to go to a website. In the URL(address) bar, type the gateway address and hit enter(see image below). A log in box should now show. Again, reference your router manual if you do not know the administrative password. Enter in your password and username.
Once you log in you now have access to the router settings and you can configure what you please. What we are looking for in this article is the wireless security settings. In the wireless security settings page you should be able to see the password for your wireless network and change it. If you see no password go ahead and set one up.
**You can also look around and modify other settings. You can change the wireless security, give your wireless network a name(SSID field) and even with some routers have built in testing features to test the connection at home.
I would recommend that if your router has a default password for admin/configuration access, that you go ahead and create a new one. The default router passwords are usually very simple and this information can be easily found on the internet by anyone. People who set up home networks tend to leave this as is and it is a security risk.
TIPS
-If you can't connect to the router and you know the gateway address, try plugging the computer into the router directly using a Ethernet cable(LAN/patch cable). If you are still having trouble, you can perform a power cycle. Turn off your modem, router and computer. After 10 seconds turn on your modem, after 30 seconds turn on your router and after another 30 seconds turn on your computer. Try to access the router now. This also helps resolve other quirky router issues.
-Make sure all the network cables, phone lines(if using DSL) and coaxial cables(cable/Broadband) are plugged in and secured firmly.
-If you set up a password and username for your routers administrative access and can't remember it, you can reset the username and password back to factory default by performing a factory reset. On most routers this can be achieved by pressing and holding the small reset button on the back of the router for 15 seconds. Please reference router user manual for more information.
I hope this article was informative. Thanks for reading.
Regards,
G33k
Keywords
Where can I find the WEP key on my router?, How to reset router WEP key, lost router security key, where can I find router password, how to reset router password, where to find router security key, how to configure router security, how to configure router password, how to configure router WEP key, lost WEP key, reset WEP key, can't find my pass key, lost router pass key, lost router wireless pass key, how to reset router passkey, how to obtain router passkey
on Jun 01, 2011 | Computers & Internet
What will i do if i forgot my security key???
All you have to do is connect to the router and change security key/ secure the connection. Just follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router)
(unless you've configured otherwise, the default username is admin and the password "leave it blank") and lookup for the options to do the following: -
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Setup" 2.Under "Wireless Security Mode", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above step would prevent unauthorized access to your router)
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
In case you have forgotten the User Name/ Password of the router, there is no way to recover the lost password However, you can reset the router to factory defaults and re-configure settings like password, network key etc. First, to reset the router to factory default setting, press the reset button at the back of the router.
Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
Please, refer here to download the product guide/manual and make configurations as per the details provided by your Internet Service Provider (ISP).
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 01, 2011 | D-Link AirPlus DI-524 Wireless Router
Web key wireless internet service
I think you meant WEP key. this is a wireless encryption security key. and it is normally required when you try to connect to a secured network. Your administrator should be able to provide you with this. because it varies. i.e you can set it to whatever you want if you have access to the wireless router. in your case Belkin 54g Wireless DSL/Cable Router
so please if you have access to it, log in to the router and check from wireless security settings.
Regards
May 20, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
My securty lock is on and i lost wireless netwert
Connect your computer to the router using an ethernet cable to allow you to access the setup page of the router and get the wireless key. Or if you already have another computer connected to the router then you may use that.
Open a browser and type 192.168.2.1 in the address bar. Then enter. By default the password field is empty.
Once in the setup page, go to Wireless -> Security. Take note of the Pre-shared key (for WPA security) or WEP key.
On your wireless computer, type the Security key to connect wirelessly.
I hope this helps!
Mar 04, 2010 | Belkin F5D8631-4 Router (F5D8631au4A)
Lost key
You cannot disable the immobiliser. If it were that easy, any car theif could defeat it by searching the internet. If you dont have any more master keys, you will have to have your local Toyota dealer reseed (reprogram) the immobiliser code, and program new keys for you. It should be about 2 hours labor and cost of keys, but only a dealer can do it. They need to use the Toyota scan tool, and access a Toyota only website with security codes.
Jan 28, 2009 | 2002 Toyota RAV4
Lost wep key for router
Hold down the reset button for 30 seconds to restore the default settings, it removes all security and the wep key.
Jan 06, 2009 | AT&T 6850G Router (ALL07735)
I lost the instillation CD and need the wep code
The WEP code is whatever you make it when you set up the wireless connection. If you have lost this key. It is best to use the manual reset located on your wireless router. Will require a small point like a paperclip. Then you will have to access the router and set up the wireless internet over again. Then you can secure it with a new WEP key.
If you need further assistance please ask me.
Thanks,
Lee
Jun 17, 2008 | Belkin (F5D7633UK4A) Wireless Router
LOST SECURITY KEY
Sivi,
All you need to do is access the router setup page and check the network key from there. You can go this link and use it as a guide on how to access the router and check the security set on it.
May 20, 2008 | NetGear DG834G Router
Lost code
if you open a internet browser and go to 192.168.1.1, that should take you to your router configuration page. from there check security or wireless security and it will give you your key.
Feb 12, 2008 | Computers & Internet
D-Link AirPlus DI-524 Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
