I am trying to get the case open for a memory upgrade.... Cannot do it!
    President:
  • 1,851 Answers
Could please clarify me your desktop's tower or laptop's brand / model?
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 07, 2010
How to upgrade memory
on the back unscrew the screws there are two places memory could be held take both of one wil be hard drive and other memory
if you have 2 slots put 2x2gbs
if you have 1 slot put 4gb memory in
let me know for further guidance
Mar 30, 2013 | Gateway LT4008u Atom N2600 Netbook
HOW do you open an acer one to access memory slot and hard drive?
Hi James, Here is a step by step video tutorial.
Enjoy your new upgrades.
Oct 22, 2011 | Acer Aspire One D255-2670
Hi. My Dell Inspiron 1525 is not working. The message is try to reseat the memory. What should I do?
If you've added/removed/upgraded the memory recently, the answer would be to open the system up and remove the memory dimms, then pop them back into the original slots they were in. It could be that one of the memory dimms aren't correctly seated in the slot.
If you haven't had the system upgraded recently and you don't want to open the system up the only answer is to take it in to the service center and have the memory dimm/s reseated.
Worst-case scenario is that the memory dimm in question is faulty and needs replacement. This isn't very likely, but definitely possible.
Good luck.
Apr 16, 2011 | Dell Inspiron 1525 Notebook
I need to put more memory chips in. where do I do it--the monitor or tower? how do I open the cover?
The memory goes in the tower on the motherboard. Most cases come apart by unscrewing screws on one side of the back. Some have a little lever on the back that, when pushed, releases the side of the case that is opposite the motherboard.
Some cases have a button (large or small) that is recessed into the top and maybe the bottom of the case. When pushed these buttons release the catch inside the case and you can swing it open.
Once open, you will see the memory slots. By pressing the catches on each end of the memory chip, you can release them and lift the chip out. Note the position of the key on the chip socket and the slot in the memory chip when reinstalling memory.
Jan 01, 2010 | Compaq FS7600 17" Flat Glass Monitor
Opening the Dell DHM case?
there is button at the rear top and rear buttom of the machine. press the button and swing open one side of the machine.
to get to the memories, you have to be very careful about the wiring, it is tight and not much space for you work in. do not lay the machine on its side,
May 13, 2009 | Dell Dimension 2400 PC Desktop
Need case removal and upgrade instructions for Compaq 5400US
Use this HP/Compaq link for your case removal & memory upgrade procedure.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03886&lc=en&dlc=en&cc=us&product=93284&rule=29389&lang=en
Cheers,
gurutim
Mar 19, 2009 | Compaq Computers & Internet
Memory upgrade for laptop
Older laptops can be VERY fussy about the memory ... you have to have the exact same 'speed' .. I had a similar problem after trying to upgrade an old machine that took slow memory (PC100) with a FASTER (PC133) module ...
NB> Some VERY old machines would not take 'double sided' modules ... check the manufacturers specs ..
Apr 17, 2008 | Computers & Internet
HP Pavilion s3020n memory upgrade
They are usually in a plastic caady which has a latch on it find the latch and release the caddy hope this helps
Dec 14, 2007 | HP Pavilion s3020n (882780985063) PC...
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
