Question about Samsung Office Equipment & Supplies
How do I replace the pick up roller on Samsung scx4720fn
  • kjm119 Sep 07, 2010
    Makes sense now part is being del. on Fri Thanks Ken
    Genius:
  • 1,478 Answers
The easiest way to do this is to stand the printer on it's end with the Tray cassette removed. You will see a small white tab to the left of the pickup roller, you can use a car key or small flathead screwdriver to release the tab, it will rotate 90 degrees upward, then probably pop off (if not, slide it to the left to pull it out of it's hole), this will allow the pickup roller assembly to slide to the left.
Next, you will find a similar tab on the right hand side, which can be released in the same manner as the left hand tab by prying upward on it with a key or flathead screwdriver. this will release the pickup roller from the pickup drive shaft and allow you to work the roller assembly out of the printer.
Follow the same procedure to fix the replacement roller.
Take care.
Posted on Sep 07, 2010
I refill the toner for samsung scx4720fn .Now its show toner empty replace the toner on the printer lcd. How i can slove this problem.
Dear raju
Pl. replace the toner chip with a fresh. As the toner chip known as CRUM stores the data about toner and printer irrespective of physical qnty. of toner. The chips are available in local market also you can search with on line stores like ebay,amazon etc.
Thanks.
Mar 16, 2015 | Samsung Office Equipment & Supplies
How do you get the Tray 1 pick up roller out of the Samsung laser printer model CLP660ND.? I need to replace it
This is the easy bit:
Turn the printer over so that you can get at the bottom. Remove the tray and the roller simply slides off.
Slide the new one on and you are sorted.
The only problem is that the Replace Pick-roller message will not go away! There MUST be a way of resetting it, but nobody who knows how to do it, is letting on how!
May 12, 2011 | Samsung CLP-660ND - - colour - laser -...
Samsung CLP-300 paper does not seem to be catching when printing?
Hi. Kelly,
I think the issue is the due to paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam etc.. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with damp (with luke-warm water) and lint-free cloth. I hope this would fix the issue. If the Roller is damaged or worn out, it needs to be replaced.
Hope this helps! Good Luck!
CreativeTECH
Feb 15, 2011 | Samsung CLP 300 Laser Printer
My printer pulls multiple sheets at once.
yo have to:
1. Clear paper pick up roller whit wet cloth or alcohol
2. Clear separation pad (located under pick up roller) using same way as pick up roller.
Good luck
Jun 18, 2010 | Samsung ML 2010 Laser Printer
How do I replace the tray 1 pick roller for my samsung CLX 3160FN printer?
Take out the tray, and you will find a pick rubber roller at the base.
Even you may clean and use it.
Jan 07, 2010 | Samsung CLX 3160fn All-In-One Printer
Not picking up paper
The roller can be replaced, #JC73-00239a, a little tricky to get the old one off and new rubber installed, but much less than a new printer.
Nov 23, 2009 | Samsung ML-2510 Laser Printer
382 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
