Question about Amana AAC051FRB Air Conditioner
Code b1 or 81 on temp panel - Amana AAC051FRB Air Conditioner
Temp display on door is giving wrong display
this is a fault code.. take a picture of the panel and post it here also picture of the model and serial tag.....I can find the fault codes with the info asked for............ ken
Sep 30, 2014 | Refrigerators
Tip
SONY PFM-42B1E FLASHING ERROR CODES
Ok i have here the problems that occur when the red standby led flashes on these sets which is an error code.
2 FLASHES ( PAUSE ) 2 FLASHES = X SUS TEMP (DD CON)
3 FLASHES ( PAUSE ) 3 FLASHES = Y SUS TEMP (I/O BLOCK)
4 FLASHES ( PAUSE ) 4 FLASHES = CENTRE TEMP
5 FLASHES ( PAUSE ) 5 FLASHES = DIGITAL 5VOLT
6 FLASHES ( PAUSE ) 6 FLASHES = PDP PANEL FAULTY
I hope that helps you cheers.
on Nov 11, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Furnace quits with 4 blinking lights on panel
Most likely it's a sensor triggering the unit off. You need to have someone determine which lights are blinking (there is a code to them) and then find out what the code refers to. Could be a simple as dirty filters.
Mar 07, 2014 | Heating & Cooling
Heating
Check your fans, each and every fan shoul be working when temperature reaches above normal also look for any water leaks.
Mar 26, 2013 | 2006 Opel Zafira 1.6
Just installed whirlpool rbs305 oven. Get error code E-5 on the panel. What does this mean. When I press bake button and then try set the temp nothing comes on the control panel, doesn't say bake and...
EVERYTHING I SEE ON THE E-5 OR EVEN THE F5 CODES are related to the door latch mechanism/switch may want to make sure the wire to the door latch/switch is ok and connected/// i hope this helps you out coming straight off the whirlpool / kitchen aid site though what those codes are related to....good luck
Jan 05, 2011 | Kitchen Ranges
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
Strange code on temperature panel, blinking 88 88/A8 w/no respons
Press both power cool buttons at the same time, until you here a chime (about 3 sec). This should solve the problem.
FIT FiNallee
Dec 27, 2009 | Samsung RS2630SH Side by Side Refrigerator
Whirlpool Range Error code F1 F3
Unplug the range.
Remove the rear panel to access the temp probe.
Unplug the temp probe and test for 1100 ohms.
Test the temp probe to ground also.
Sometimes the connectors are bad.and must be direct wired.
Unplug and re-plug the ribbon connector to the ERC.
F-1 is a connection problem since you have a new control.
Mar 14, 2009 | Kitchen Ranges
U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Oct 03, 2008 | Office Equipment & Supplies
Fault code f1 came on during a cleaning -
On maytag f1 means there is a problem in the control (erc) and will need to be replaced.
Dec 26, 2007 | Maytag MER5870 Electric Kitchen Range
Amana AAC051FRB Air Conditioner Logo
43 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
