Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
1/2"ice on the botom - why? - Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 12, 2010
Ice falls out of drawer when open up
if its a no frost refigerator sounds like you might have to take all the drwars out unscrew or detach the back plate and defrost the fridge manually and then unblock the drain hole which goes to the back of the fridge into a plastick container ontop of the compressor which in turn will evaporate from the heat of the compressor . Hope this does the trick
Apr 30, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Please tell me how to use rival ice maker model GC 8250
Go to this link:
http://www.rivalproducts.com/help.aspx?helpNav=5
Ice maker manuals are near the botom of the page. I do NOT see the GC8250 listed. If this is your model number can you pass your geograpic location (not address) So I can have an idea of where to search.
Thanks for choosing FixYa,
Kelly
Jul 03, 2011 | Rival Microwave Ovens
Gr-892deqf trouble shooting we saw water on the ground near the botom of the refegeratore i discovered that there is ice accumelation on the step looking at the back of refeg. behind the to end of the...
You have a defrost drain that in blocked. Try looking in the back and very bottom of the freezer and locate the drain. Also you may have to pull the refrig out from the wall to get to the drain that way.Hope this helps.
Jul 01, 2011 | LG Refrigerators
I have an amana br22 the botom freezer gets an ice block on the radiator coils then air flow slows down to top section i have to hot air gun the freezer to get the air to start moving
The ice block is due to a defrost circuit failure. Typical problems are due to the defrost heater, defrost timer if used on this model and defrost thermostat. Since you are using a heat gun to melt the ice, check the the defrost heater with a meter to determine whether it needs to be replaced.
Aug 23, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
AMANA FRIDGE ARB190RCW FREEZER AT THE BOTOM. FRIDGE IS RUNNING BUT NOT COOLING. FREEZER BACK WALL FULL OF FROST
Switch off unit for 12 hours and do a proper defrost. once all ice is gone, switch back on and take note if evaporator fan is working.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Model 106.54619300
not knowing your ice maker model
if you have a white box like cove on the end,
pop that off
you will be looking at the ejection moter wheel
to the botom right, you should see two holes
one T one H jumps those out with a small peice of wire, you may need to hold the door switch on the freezer,,,,
if you jumped it out correctly, yo will hear a definitive click,
take out the jumper
watch the whole cycle 3=mins
keeping an eye on the ice machine the whole time
if it does everything but eject your motor is stipped
and you will need a new one
Oct 06, 2009 | Kenmore Refrigerators
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
Freezer forms ice on botom under tray panal and water runs down in fridge
you have a iced up evaporator, try defrosting it by switching it off for at least 12 hrs, check timer and defrost heater.
May 03, 2009 | Freezers
Water from ice makers leaks and builds up in botom of freezer
ice maker leaks are usually a sign of icemaker mold corrosion eating the lining off the icemaker causing it to leak. the only repair is to replace the complete icemaker. you will need a complete model number from the unit and the part can be ordered online thru whirlpool or some of the other appliance parts sites. you may even have a local parts warehouse where you live. hopw that helps peyton
Jan 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
