Question about Alpine CHM-S620 6-Disc CD Changer
Alpine CHM-S620 CD Changer Magazine
My magazine on my alpine cd changer got stuck i dont know what to do i took it apart but there is no way to unjam it so i dont know what to do now its just stuck it wont eject and then on the radio it says CDE-1 thats it and it wont do anything else.
If you open the cage on the unit, you can pop the tray back out of the mechanism by VERY GENTLY turning the load gear on the carriage, be sure to not slip any gears on the drive or the changer will be out of sync and will be garbage unless you have it serviced by an Alpine service center. you are best to turn the 1st. gear beyond the carriage motor, or you can apply power to the motor (which I don't advise) to let the motor eject the tray. if you do choose the power method, be 100% sure of the polarity first otherwise you will damage the carriage and drive gears. the motor has a brass gear and the rest are nylon gears, the brass gear will very easily shred a nylon gear. want to be extra careful? manually turn the load motor gear itself, it will take alot longer to do, but will be the safest. I've been inside these machines quite a bit, hope I was able to help.
Posted on Sep 18, 2008
Dont know how to put disks in
You may download a copy of the manual here. The second page describes how to put discs into the magazine and the magazine into the unit.
Feb 17, 2012 | Alpine CHM-S620 6-Disc CD Changer
Error 01 the magazine does not eject
A lot of times there is a gear inside of the changer that gets jammed. If you can, remove the top cover of the changer. On the changer mechanism (it will be on the right side of the changer) there will be a large gear (probably black) with an arm attached to it. Use a flat blade screw driver or something like that and turn the gear counterclockwise until the tray is back in magazine. You should then be able to put the changer back together and it will probably work fine.
Nov 02, 2011 | Alpine CHM-S620 6-Disc CD Changer
Where can I buy a magazine for the CHM-5611?
Go to a magazine store at your local mall. or a book store.
Jun 13, 2010 | Alpine CHM-S620 6-Disc CD Changer
The 6 disc magazine will not eject -
Ok..just happened to me. I'm a tinkerer so it's assumed that everything is out of warranty. The low down and skinny is this. The last disc holder is stuck on the metal changer tab, preventing the magazine to eject. 1. Remove the six screws on the left and right sides. 2. Use a small flathead screwdriver to GENTLY pry off the front Alpine CHM-S620 plastic facia.\ 3. On both left and right sides, collapse and push in the rubber suspension mounts. 4. Carefully remove the vertical/horizontal mount springs. 5. Gently pull off the data cable ribbon. 6. Flip over the changer unit. Use a coathanger to gently push the cartridge back into magazine. **You may damage the cd and last holder. Small price to pay to get things back to working order though. You may also have to wiggle the last cd holder to get it over the metal lip. 7. Reassemble in reverse order. 8. Change out that last cd cartridge so it doesn't jam again. Good luck.
Sep 27, 2009 | Alpine CHM-S620 6-Disc CD Changer
My Alpine CHM-S620 CD changer broke down and so I
Check out . you can cross-reference your vehicle model and they will show you what is available for your vehicle. They carry a large inventory and I have purchased from them several times.
Sep 26, 2009 | Alpine CHM-S620 6-Disc CD Changer
How do I find the model number on my Alpine cd changer in my 2002 Laguna as I need a magazine for it and have no manual.
There will be a silver or white tag on the back with the model and serial # on it. If it's not there, just visit a car audio shop that sells Alpine, any experienced installer with one look can tell you what it is. Hope this helps
Jun 24, 2009 | Alpine CHM-S620 6-Disc CD Changer
Have alpine chm s620 ,error message say no disc magazine is loade
have you tried a different magazine.  Could this one be warped?
Apr 03, 2009 | Alpine CHM-S620 6-Disc CD Changer
Which radio for land rover
Usually an Alpine unit.  Try ebay.
Mar 24, 2009 | Alpine CHM-S620 6-Disc CD Changer
Chm -s620 cd changer not loading cds
I've got the same problem with my Alpine changer. It seems like a widespread problem, but known cause or solutions.
Apr 03, 2008 | Alpine CHM-S620 6-Disc CD Changer
Alpine CHM-S620 Tape/CD button inoperative
Dont know Steve, i am no fundi with electronics but could it be that your system is set up for the steering remote, or perhaps not activating because of a wiring or button contact issue ?
Hope you get it sorted out.
Oct 30, 2007 | Alpine CHM-S620 6-Disc CD Changer
Alpine CHM-S620 6-Disc CD Changer Logo
579 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
