Question about Vtech Cordless 6041 Phone
Both of my phones say 'out of range or no pwr at the base' both phones are on the base, and both are plugged in. I am kind of disabled right now and depend on the home phones
Trying to register my CL84252 at&t handsets to the base but the handsets keeps displaying an error message "out of range or no pwr to base"
Check to make sure the base station does have power. If it does have power the base station is defective or the handset is the problem (systems with just one handset), if all handsets display the same error then it is the base.
Nov 03, 2016 | AT&T Lands Phones
Ican call out but calls
Reset the phone to the factory settings
Jun 09, 2008 | Lands Phones
I cannot get the handsets to charge.
Sounds like your rechargeable batteries have reached there usefulness.
Oct 26, 2015 | Vtech AT&T CL83213 2 handset cordless...
I have hooked up my phones but all I get on the hand sets is no pwr at base and out of range, how can I fix this, I have already tried disconnecting and reconnecting
Is the base unit being powered up? Is the adapter that plugs into it working and supplying power to the base? If not nada will work and you will get the out of range indication on remote handsets.
Sep 26, 2015 | Vtech ATT CS6629-3 CS6629-3 DECT6.0 3...
After charging battery,the phone dial reads, out of range,or no pwr at base
Double check that the power cable is _fully_ plugged into the phone base, then check to see that power cable is fully plugged into wall outlet; and/or fully plugged into phone wall outlet. (Some base units have no power adapter and get their power from the phone outlet on the wall). In short, double check _all_ wired connections. Do not assume they are fully plugged in.
Aug 15, 2015 | Vtech VT-CS6114 Cordless phone w/ CID/...
My handset says it is "Out of range or no pwr at base". Please tell me what to do?
If there is that message and you are close to the base AND the light and phone appears good, then the issue is the transmitter power in the handset.
Jan 09, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
Out of range or no pwr base vtech phone on help
Try disconnecting the base from the power supply. Then take the battery out. wait a few minues, then plug baack in and reinsert the battery, and it should work. You might have to reset the date and time. \check the V-Tech site for instructions.Good luck.
cherriwh
Sep 10, 2012 | Vtech 9009111 Cordless Phone
I've been receiving this error message, "out of range or no pwr at base" on my vtech CS6329-3 for the last 4 days. Help!!! I bought the cordless phones thru my Airmiles program in Oct...
The phone is not charging or the batteries are bad. You will need to get another set of batteries for the cordless phone. Call the customer service desk and tell them that they need to send you a repalcement phone. The phone is not properly charging.
Nov 26, 2010 | Cell Phones
Vtech Cordless 6041 Phone Logo
285 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
