Question about Olevia LT23HVX 23 in. LCD Television
23" olevia lcd does not turn on
I plugged the usb cord to the computer to charge the on off because it just would not turn and it turned on while the usb was connected from the tv to the computer then when we put it back to the cable box it would not turn on does it have to charge for a certain amount of time
  • almac508 Aug 12, 2008
    i dont see a usb plug in on the back of my set. can you help
  • 3 Answers
The adapter is USB on one side, and the real little connector that is on the other end, used on Sony Camera upload cables and such. Looks like a mini VGA connector, without pins in it.
I am now using the Olevia as my computer monitor, to see how long it will go for.
Once the monitor was up and running, the cable/adapter was not needed.
I think this is a lesson to put all your tvs and monitors on UPS with AVR tehcnology. The spikes that come through telecom and cable companies can fry components.
Will order the diodes and do the self-fix at some point.
Only problem now, monitor base has no TILT capability..... Setting without angle is weird
Jeff
" Jim, I am a Locksmith, not a tv repairman "
Posted on Oct 26, 2008
Plugging in the USB worked for me too!
Posted on Jun 10, 2008
Tv won't turn on no blue light either
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 14, 2014 | Olevia LT23HVX 23 in. LCD Television
Red lite comes on but tv will not power up.
Follow the solution for service port 'jump start' with a usb plug. Plug your cell phone charger in next to the TV. Touch the metal prongs of the service port with the metal part of the usb until you get a brief 'flash' on the TV. Then turn on the tv set. It takes patience and a flash light to do this, so you can see what your touching, as my husband couldn't get it to work, but I could.
Apr 20, 2009 | Olevia LT23HVX 23 in. LCD Television
OLEVIA LT23HVX
gary, thanks so much for taking the time to reply. i tried the USB gig but no luck. how hard is replacing the capacitors? i am fairly handy. where do you get new ones? this will be my last olivea! these are junk. my first one went out and i sent it back. took them 3 months to send another. it last 2 months and now it is dead? major pain in the ***!
thanks!
jeff
Aug 15, 2008 | Olevia LT23HVX 23 in. LCD Television
Olevia - hidden mini HD service input
I have pictures of the USB port, as well as the procedure of what I did, once the USB trick quit working here: http://www.flickr.com/photos/geegee123/sets/72157607269121264/
Jul 23, 2008 | Olevia LT23HVX 23 in. LCD Television
Power on problem for My Syntax Olevia LCD TV 23"
I have a 24" Olevia LCD TV. Same symptoms (Stdby LED is on, press power and it flashes off, then back on). The USB cable to the Service Port also worked. But being of sound technical mind, I figured this means that the PC is supplying the +5v to the circuit. What I did was disassebled the TV, carefully disconnected all the cables, and opened it up to reveal the circuitry. I looked over the circuit and noticed the 1000uf/16v capacitor at position CS21 was failed and bulging. I removed the cap, tested it and verified that it was indeed failed. I went to a local Radio Shack and picked up a 1000uf/35v electrolytic, after all, the value is what mainly matters as long as it's not lower voltage than the original. I replaced the new CS21 capacitor back in the circuit (it is polarity sensitive, so pay attention to what the original mounting position is). I reassembled the TV and Viola! Works! No need for the USB cable to the Service Port!
I hope this helps someone!
-Matt
May 21, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Can't turn tv on
Follow the solution for service port 'jump start' with a usb plug. Plug your cell phone charger in next to the TV. Touch the metal prongs of the service port with the metal part of the usb until you get a brief 'flash' on the TV. Then turn on the tv set. It takes patience and a flash light to do this, so you can see what your touching. This will not turn on the set. You still have to do this yourself after the flash.
May 08, 2008 | Olevia LT23HVX 23 in. LCD Television
My service port looks like an 8-pin mini din mouse port
If you are just trying to 'jump start' the tv to turn it on, get a usb cable, like the one you use to charge your cell phone. Touch the metal part of the service port, the 8-pin mini din witht he end of your charger cable that is plugged into the wall, until you see a flash on the screen, then turn the tv on like you normally would. It should turn on. If it doesn't jump it again.
Mar 16, 2008 | Olevia LT23HVX 23 in. LCD Television
power supply board is the board where the ac cord plugs in .the . capacitors have numbers printed on board right beside them. there are three to change also check fuse on the board to.
Mar 12, 2008 | Olevia LT23HVX 23 in. LCD Television
Olevia won't turn on.
I posted photos and a description of my solution for this problem here: http://www.flickr.com/photos/geegee123/sets/72157607269121264/ There's another thread on FixYa dealing with this same issue that has a variety of solutions as well.
Mar 04, 2008 | Olevia LT23HVX 23 in. LCD Television
My olevia LT23HVX does not power on
If you want to see photos and a description of the disassembly process and commentary on my repair job, soldering in the new caps, etc. I've posted them online for anyone interested in tackling the job themselves. I've never cracked the case on a TV before, but thanks to some of the hints here, and some efficient Googling, I was able to fix my own set with a screwdriver, pliers and a cheap soldering iron, all for less than the price of a pizza.
Nov 01, 2007 | Olevia LT23HVX 23 in. LCD Television
Televison & Video Logo
87 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
