Question about Spectralink NetLink SVP (SVP100A)
No SVP response is shown on the display and the SVP IP address is the same each time indicating one of three SVP's in production, however multiple handsets are registered via each of the three.
Minolta Bizhub 362. Brand New. After configuring IP address, it asks to switch off and on again. when switching on, displays "please wait". Do not go further.
Restart the machine and wait for some time.If the basic screen shows and machine can make copies then its ok if not then again go to the administrator mode, network setting, check the ip if there is no ip then some of the options are missing.call your technical services representative or tell me in detail by email
xeerie@yahoo.co.uk
i will try my best to help you..
May 25, 2011 | Konica Minolta Bizhub 362 Copier
Where can ip address for my acer one aspire netbook
  • Go to the Start menu, go to Run, and type "CMD" in the dialog box (without the quotes.)
  • jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a01/vq/ee/computer-ip-address-windows-1.2-800X800.jpg'); });
    Now you should see a dark (DOS) window that looks just like the picture on the left of this article step.
    Without the quotes, type "IPCONFIG" and press ENTER.
    Now you should see some network information, along with the IP ADDRESS of your computer listed.
    Read more: How to Find Your Computer IP Address (Windows) ' eHow.com http://www.ehow.com/how_2091470_computer-ip-address-windows.html#ixzz19FT6QSK3
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
    Thanks, Joe
    Dec 26, 2010 | Acer Aspire One PC Notebook
    Ip address in invalid on windows vista
    All we need to do is to reset the router for about a minute, if we are still getting invalid IP which is 169.x.x.x then we need to temporarily assign an ip address on the computer.
    How to assign IP address:
    Windows XP
    Step 1: Click Start, then Control Panel.
    Step 2: When the Control Panel window opens, double-click Network Connections.
    Step 3: Right-click Local Area Connection, then click Properties.
    Step 4: When the Local Area Connection Properties window appears, click Internet Protocol (TCP/IP) then Properties.
    Step 5: Change the option from Obtain an IP address automatically to Use the following IP address and enter the following:
    Make sure the IP Address you'll be assigning the computer has the same first three numbers as the Default Gateway and the last number can be any number between 2 and 99. In this example, our Default Gateway is 192.168.1.1, so the IP address that should be used must start with 192.168.1. In this example, the IP address that we'll assign is 192.168.1.50.
    • IP: "192.168.1.50"
    • Subnet Mask: "255.255.255.0"
    • Default Gateway: "192.168.1.1"
    After assign static IP then click OK.
    Step 6: If we are not getting any response from the router(like pinging the ip address of the router) then possible product is defective.
    Dec 22, 2010 | Computers & Internet
    I want serial key the hide your ip address product
    Such software products do _NOT_ work -- your IP-address is needed so that any "responses" to TCP/IP packets that you "send" can be delivered "to" your IP-address.
    Nov 15, 2010 | HideYourIPAddress.net Hide Your IP Address
    I'm forget admin password on hp 9250c. Please, how recovery admin password.
    Cold reset for HP9250C
    A cold reset resets the values of permanent storage variables to factory default. Often this is necessary
    for clearing the HP MFP Digital Sending Server IP address.
    The following items are cleared during a cold reset:
    Embedded Jetdirect IP address
    SMTP IP address
    LDAP IP address
    Embedded Web server password
    All control-panel configurable items
    The following items are NOT cleared during a cold reset:
    Local address book e-mail addresses
    Real-time clock (date and time)
    Page counts and maintenance counts
    Product serial number and formatter number
    Service ID
    Event log
    To perform a cold reset
    1. Turn off the digital sender.
    2. Turn on the digital sender.
    3. Immediately after turning on the device, press and hold down the #6 key (do not wait for the memory-count). When the three status LEDs are illuminated, release the #6 key.
    4. Press the #3 key four times until the display shows COLD RESET.
    5. Press the #6 key once to initiate the cold reset. The product will continue its boot-up sequence.
    Oct 04, 2010 | HP 9250c Printer
    How do i reset the entire system back to default? Previously someone had put an admin lock on it so now i cant use it properly and i need to reset the menus.
    Hi
    · It is called the Cold reset
    A cold reset resets the values of permanent storage variables back to factory default. Often this is
    necessary for clearing the HP MFP Digital Sending Server IP address.
    ● Embedded Jetdirect IP address
    ● SMTP IP address
    ● LDAP IP address
    ● Embedded Web server password
    ● All control-panel configurable items
    ● Local address book e-mail addresses
    ● Real-time clock (date and time)
    ● Page counts and maintenance counts
    ● Product serial number and formatter number
    ● Service ID
    ● Event log
    3. While the product is performing its memory count, hold down the #6 key. When the three status
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Feb 02, 2010 | HP Digital Sender 9250c scanner Printer
    How to give ip address to workcentre m133 network printer
    : You must be a System Administrator to perform this solution. 1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed. 2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen. 3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen. NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed. 4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed. 5. Select [System Settings] twice. The System Settings screen will be displayed. 6. Select [Network Settings]. The Network Settings screen will be displayed. 7. Select [Protocol Settings]. The Protocol Settings screen will be displayed. 8. Select [TCP/IP - Get IP Address], and then select [Change Settings]. The TCP/IP - Get IP Address screen will be displayed. 9. Select [Manual], and then select [Save]. The Protocol Settings screen will be displayed. 10. Select [TCP/IP - IP Address], and then select [Change Settings]. The TCP/IP - IP Address screen will be displayed. 11. Enter the machines IP Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 12. Select [TCP/IP Subnet Mask], and then select [Change Settings]. The TCP/IP Subnet Mask screen will be displayed. 13. Enter the machines Subnet Mask using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 14. Select [TCP/IP Gateway Address], and then select [Change Settings]. The TCP/IP Gateway Address screen will be displayed. 15. Enter the machines TCP/IP Gateway Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 16. Select [Close] three times. 17. Select [Exit]. The machine will reboot automatically.
    Jun 09, 2009 | Xerox WorkCentre M15i Laser Printer
    Samsung SGH-D600
    First providing the entire text of the message in a comment here would provide useful information to resolve the error.
    Second a short discussion of DNS. DNS from your perspectiveis generally several servers assigned by your ISP to provide the data to convert names such as www.FixYa.com to numeric IP addresses to send messages. Generally in a home network these DNS addresses get configured into the adapter automatically from the router using DHCP or manually by the user.
    If your web browser can access sites by name such as www.fixya.com despite the DNS message you indicated then your DNS servers are probably properly configured and there is another DNS issue.
    If you wish to check further
    click on start than all programs then accessories then command prompt
    in the window that opens enter the following command
    ipconfig /all
    There may be multiple adapters shown but one should have all of the following as non 0.0.0.0 addresses
    IP address, Subnet Mask, Default Gateway and one or more DNS addresses. The DNS addresses present should normally match those provided by your ISP.
    IF you have any questions, can supply the full error message or believe any of the above is an issue please add a comment to this problem and I will provide any additional input I can based on your observations.
    Dec 16, 2007 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
    I have to repair my connection to get internet
    Are you running a virus scanner or internet security software?
    Is it active and has it been updated recently?
    Do you perform periodic full scan of your systems and are they clean?
    Do you run any apyware packages?
    Are they active and have they been updated lately?
    Do you perform periodic scans with them and is your system clean?
    Not all virus scanners, etc catch all problems. Some catch different items.
    Consider using free online services from some of the security vendors to double check your product. Several to consider
    Trend Micro
    Fsecure (www.fsecure.com and search for online scanner)
    Symantec
    Consider free spyware software for additional checks if you have not choosen to purchase a product to do this.
    Lavasoft
    Spybot
    Clean up the issues found and see if the problems are eliminated.
    Using the following instructions from the zonet website to get your IP address will also reveal your router's address in the default gateway entry (assuming your computer receives it's IP information via DHCP from the router or has been staticslly configured correctly). This will be the value you utilize instead of 192.168.1.1 to access the router's configuration.
    spacer.gif Q: How can I find the IP address of my computer? spacer.gif A: Windows 95, 98, and ME:
    Click on Start.
    Then click on Run.
    The Run Dialogue Box will appear. Type "winipcfg" in the window as shown then click OK.
    The IP Configuration window will appear, displaying your Ethernet Adapter Information.
    Select your adapter from the drop down menu.
    If you do not see your adapter in the drop down menu, your adapter is not properly installed.
    After selecting your adapter, it will display your IP address, subnet mask, and default gateway.
    Click OK to close the IP Configuration window.
    Windows 2000 and XP:
    Click on Start and select Run.
    Type cmd then click OK.
    From the Command Prompt, enter ipconfig. It will return your IP address, subnet mask, and default gateway.
    Type exit to close the command prompt.
    Macintosh 8.x and 9.x:
    Click on the Apple Menu>Control Panels>TCP/IP.
    Select your Ethernet adapter from the Connect Via drop-down menu.
    Under Setup, select Using DHCP Server from the Configure drop-down menu, if connecting to a router DHCP server. This is the most common setting when using a router. In this configuration, your computer will be automatically assigned an IP address by the router.
    You must reboot your computer to "renew" your IP address.
    Macintosh OS X:
    Click on Apple Menu>System Preferences>Network>TCP/IP.
    Linux:
    At the command line type /sbin/ifconfig and you will get a listing of information. Your IP is shown after inet addr.
    Dec 08, 2007 | Zonet ZSR0104CP (zsr0104cp) Router
    Spectralink NetLink SVP (SVP100A) Logo
    593 people viewed this question
    Top Spectralink Computers & Internet Experts
    David Payne
    David Payne
    Are you a Spectralink Computer and Internet Expert? Answer questions, earn points and help others
