Question about Frigidaire GLGR1042FS Dryer
Dryer runs but the tub does not turn - Frigidaire GLGR1042FS Dryer
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 10, 2010
Kenmore dryer Tub will not turn freely. Feels as if it's hung up. When you you press the start button it will just make a humming noise.
A guess, sounds like you are hearing the motor running but no tub belt as it is probably broke. If you are asking then you probably don't know how to fix it so you should call a repairman. Or the tub guides are wore out either way a repairman can help.
Nov 22, 2011 | Kenmore Dryers
The dryer in my trailor tub wont turn I have Heat but the tub wont spin.
heatman101
Mar 08, 2011 | Dryers
We have a Maytag Atlantis dryer. Inside the tub
Did you try opening up the back of dryer or the top?
Sep 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
The tub in my dryer quit tumbling and it's not the belt around the tub what else can i try
Hi, Does the motor run but the tub does not turn? If you would get me a model #, I can look this up and give you more instruction.
Vic
Jul 01, 2009 | Dryers
Dryer tub turns but there is no heat
I have a frigidaire crown series dryer.the tub turns,timer works but there is no heat coming out.
Jun 23, 2009 | Whirlpool Dryers
Motor shuts off, and resets after a few minutes dryer wont run
May be the tub support rollers, If this is problem you will have to remove the tub. Then check rollers to see if they turn free. If not replace the faulty ones. This drag on the motor will cause it to get hot.
Mar 29, 2009 | GE DBXR463EDWW Electric Dryer
Dryer will not turn
There is a belt like a fan belt that goes around the outer tub and onto a pulley that turns the tub, it may have slipped off, you should be able to take the top off of the dryer to check it.
Mar 19, 2009 | Maytag PYE2300AY Electric Dryer
Dryer won't stay running
Sounds as if you have a belt or tub roller problem. Either can be fixed fairly easy but you will have to remove the tub. This is normally done by removing the top, then the front of the dryer. It would help a lot if you had someone to help you remove the tub.
Feb 27, 2009 | Whirlpool LER4634J Electric Dryer
Dryer tub won't turn
hear the motor running, just not spinnig drum? if so you problably eiteh threw the belt off pully it broke all together. theres 2 screws holding the front panel on apprx 10 in. up and 2in. in, slightly pointed upwards. rmeove them and the front panl comes off, i believ the top might just tip back at that pint in which case youll see the belt wrapped around the drum. ro where it should be wrapped around anyway. new belt num Y312959.if needed, youll need to reach beltto motor pulley from behind unit through a small acsess hole. be carefull not rip bag bael is in because it shows placemnet of tension pulley and correct direction to wrap belt in.anything past that, im thinkin 18 yrs has been a good run, go for new
Mar 01, 2008 | Dryers
Ge dryer shuts off
turn the drum by hand see if it turns fairly easy if it does then you may need to replace or clean the drive motor if not may need to service the tub rear bearing tub glides etc
Dec 30, 2007 | GE DBSR453EBWW Electric Dryer
Frigidaire GLGR1042FS Dryer Logo
41 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
