Question about Bushnell Neo Handheld GPS Receiver
Lost a rubber (advance) button off my Neo Gps unit...is there a replacement?
Why doesn't it charge?
Three things.
Charger not putting out current.
Battery faulty or disconnected.
Unit faulty.
Aug 24, 2015 | Bushnell Neo Handheld GPS Receiver
I have a SGX and have lost the antenna cover. Can I find a replacement?
Stay AWAY from the SGX. The quality control is really poor. I know of three other users having the same problem, the antenna cover falls off and the unit does not get satelite reception. It becomes a piece of junk. Once that unit got replaced, in less than 5 months, the rubber covering the knob that allows you to select items had a tear and now the unit is no longer waterproof. This is not covered under warranty and they want you to pay $89.95 for a replacement. I am done with SkyCaddie. I have just purchased the new Garmin G6, awesome device, no annual fees, long battery life and touch screen enabled.
Look at the following link to get other user experiences.
Amazon com Customer Reviews SkyCaddie SGX Golf GPS
Feb 09, 2015 | SkyGolf SkyCaddie SGX GPS Receiver
Can't load new roll of paper
The rubber sleeve on the paper advance shaft has likely lost it's elasticity. It expands then the shaft just spins inside of it. It's tricky but I disassembled the paper advance assembly and replaced the old sleeve with a piece of small silicone tubing. Works fine now.
Mar 31, 2014 | Texas Instruments TI-5045 SVC Calculator
Zoom in button works, but won't zoom out
I had the same problem. took unit apart and used a white rubber eraser on the button contacts and also on the rubber back of the button. Cleaning the rubber back of the button seemed to be the most important part because prior cleaning of just circuit board did not seem to have any effect. Button works fine now to my surprise. I suggest cleaning the rubber back of all buttons to avoid repeating process of having to take unit apart twice
Aug 25, 2008 | Magellan eXplorist 200 GPS Receiver
Rubber band around case got loose, then broken
I had the same problem with my Vista 1 year ago. I tried the contact cement and worked fine for a couple of weeks. I tried another brand of contact cement and had the same problem (the adhesive unsticks from the rubber band). I finally solve the problem cleaning everything (be sure to remove ALL of the adhesive from both gps and rubber band to ensure a good contact between them) and putting some drops of Locktite instant glue on the water protective layer side, and then carefully place the rubber band on its place (don't forget that you have only a few seconds to work with instant glue) . Just be carefull and don't apply adhesive very close to the buttons. It worked for me for more than 11 months....and still working...
Jul 08, 2008 | Garmin eTrex Vista GPS Receiver
Raytheon rl70
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
May 05, 2008 | Raymarine RL70CRC GPS Receiver
276C Memory Battery
There is a button cell soldered to the main circuit board that powers the real-time clock while the unit is off or the main battery is removed or flat. After a couple of years this button cell dies and has to be replaced. I've had this problem twice in five years, and each time replacing the button cell fixes the problem.
Needs a Garmin workshop, or someone who's good with a fine-point soldering iron.
Jan 09, 2008 | Garmin GPSMAP 276C GPS Receiver
Bushnell Neo Handheld GPS Receiver Logo
67 people viewed this question
Top Bushnell GPS Experts
Martin Murray
Are you a Bushnell GPS Expert? Answer questions, earn points and help others
