Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
I have the replacement line fed onto the spool for my black & decker trimmer in the opposite direction that it spins and yet the line just continues to feed when the trimmer is on and goes through the spool within minutes. Any idea why or wht I can do to correct this??
4 Suggested Answers
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
  • 313 Answers
SOURCE: black and decker grasshog trimmer line feed problem
email publication@bdk.com or see www.dewaltservicenet.com look for the find it now icon & enter the model #
Posted on Jul 28, 2008
  • 12 Answers
SOURCE: I am trying to spool
Yes, it does feed automatically.
Please make sure the trimming line spooled in your spool regularly.
If above does not work, please go to service center to change a lever inside spool housing.
Posted on Aug 30, 2008
Black decker weed trimmer
Hi Ken, If your spools are emptying by over feeding it sounds as if they are spooled the wrong way. Try re spooling one by putting the cord on the opposite way it is now. You may be getting the wrong spools or there is a fault with your trimmer.
Jul 27, 2013 | Garden
I have a black & decker gt701 strimmer. i recently replaced the line on the spool but now it wont feed, ??
Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit.
Replace empty spool with new full one or wind on aftermarket string. Wind in direction of
arrow on spool. Make sure spool is seated on rachet firmly.
Apr 16, 2010 | Black & Decker Garden
Replacement of Cutting Line! How to do? anneodello
There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Oct 21, 2009 | Black & Decker Garden
B & D trimmer feeding too much line
Do you remember putting the spring back in when you filled it with new line. You mite check to see that it is in there.
Good luck
Aug 07, 2009 | Black & Decker 14" Grass Hog Xp...
How do I refill the spool with new cord. the whole towns out of the refills. I bought new line, but cannot figure out how to wind the cord onto the black thingy. Its a dual line feed.
The grasshog xp takes .080 heavy duty line, do not use any other grade other then .080!
First remove the orange cap by depresssing the two buttons. Next unscrew the screw and remove the tumbler. You'll want about 50' of line for each of the two spindle slots. Start on the spindle closest to you by inserting about an inch of line into the hole in the base and statr winding it snugly in the direction as show on the spool, take your time and do it nice and neat and the line will last you longer then if you rush and do it sloppy. At the end leave about 6/8 inches and temporarily fasten the end on one of the nitched holders. Start the inside spool from the opposite end that you started the other and repeat the same. Once they are both spooled and temporarily fastened at opposite ends from each other reattach the spool onto the edger, fasten the screw in place and un fasten each end at a time inserting the line through the wholes each on oppoing sides. Then reinstall the safety cap and you are done! For taking 15/20 minutes and 1/4 the cost of buying a new spool and saving throwing the old spool away it is well worth it =)
Jul 15, 2009 | Black & Decker 14" Grass Hog Xp...
Threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Jun 19, 2009 | Black & Decker Garden
I am trying to spool trimming line into my black and decker GH1000. It is supposed to feed automatically. It is not. I'm afraid I fed the line onto the spool incorrectly. Need help
Aug 29, 2008 | Black & Decker String Trimmer Cordless 12"...
Changing spool on weed trimmer
unscrew the knob on the bottom(turn cc wise) pull bobbin straight out . To restring pull start rope gently to see what direction it turns and wrap string in the opposite direction. Re insert the string into the corresponding hole(s) and screw up knob by hand until tight.
Jun 22, 2007 | Black & Decker String Trimmer Cordless 12"...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
117 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
