Question about Brother Sewing Machines
I just purchased sewing machine Brother SQ9000 Heavy-duty Computerized Sewing Machine . When i wanted to wind a bobbin for the very first time i found out that bobbin shaft won't spin but I can hear the motor whiring. I did everything exactly by the instruction and it still doesn't work. What does it mean and what can i do to fix it? Please help.
    Genius:
  • 1,788 Answers
Go to brother-usa.com and you can see & download your manual for free, I also saw the quick start guide and you can blow up the diagram really large to see all of the detail. Make sure that you have your thread wound around the spindle right and you hold the thread tail for a few revolutions until it catches hold.
Posted on Sep 12, 2010
Bobbin will not wind
For ~$25 you can purchase a stand-alone bobbin winder from the local fabric store (JoAnn's, Hancocks) or the internet, ie Amazon.com.
Nov 15, 2015 | Brother CS-100-T Computerized Sewing...
I have a Brother Innovis CS8060, the bobbin no longer winds completely, only halfway, can you advise?
being a computerized machine i would take it to a service center, if this isn't an option at this time next to the post you put your bobbin on is the depth adjustment, there is a screw in the top of it very gently loosen scew and slowly rotate the depth gauge until you think it is where you want it . you may have to sdjust it a couple of times before you get it where you want it so go slowly and carefully
Nov 05, 2010 | Brother CS-8060 Computerized Sewing...
I have the Brother SE270D and when I was winding the bobbin the thread somehow slipped under the bobbin and was wound around the peg under the bobbin winding area. I thought I could remove the screws and...
You can either take the machine in for repairs or, use another sewing machine (if you have one that uses the same type of bobbin) for bobbin winding or purchase a Sidewinder Bobbin Winder - search the Internet for the best price.
Mar 02, 2010 | Brother SE-270D Computerized Sewing...
Brother SE-270D sewing machine bobbin won't wind
the rubber ring on the bobbin winder has probably gone bad which would mean replacing it but you can buy a portable bobbin winder called a sidewinder for around 20.00
Jun 16, 2009 | Brother SE-270D Computerized Sewing...
Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Sep 26, 2008 | Brother CS-8150 Computerized Sewing...
BOBBIN WINDER NOT WORKING RIGHT
Try to lift the guide before the bobbin winder, by 2-3 millimeters.
If you can't lift the guide, then put something between the two, (a magnet perhaps) just to lift the thread a little bit upwards during winding.
Jun 09, 2008 | Brother CS6000i Computerized Sewing...
Can't wind the bobbin
Bobbin will not lock on bobbin spindle, what can I do?
Mar 20, 2008 | Brother CS-8150 Computerized Sewing...
Brother PE150
You need to adjust your top tension and maybe your bottom tension ( the little screw on the bobbin cover) Also check your needle and make sure it's straight.
Feb 07, 2008 | Brother PE-150V Computerized Sewing...
Sewing Machines Logo
286 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
