Question about GE GSH22SGRSS Side by Side Refrigerator
You mean the heater and thermostat installation instruction? No.
But I had no problem with installation.
When I took off the fan box located under the ice box, there was a green wire from the box and it was connected to the back of freezer right over the box and the other end of the wire was connected to somewhere inside(I guess) the box.
but I don't remember where.
and one more question.
I melted all frost and replaced defrost heater and thermostat.
but If it's not cool enough and NO ICE, what should I do?
Thank You so much..
  • 975 Answers
Give it a couple of hours ,so system can function , also set the knob to high , and let me know later AJ THANKS FOR THE RATE !!!!
Posted on May 14, 2008
Fan relay location
what vehicle ?? usualy in fuse box under hood some are on or neer rads or do you mean heater fan the will be under passenger side dash in the heater box follow wires back from the heater motor they are attached to the relay some are real pain to get out
Aug 15, 2014 | Cars & Trucks
1983 ford ranger 2.2 engine-no heat,full of anti-freeze,replaced thermostat 195 degrees,found a bunch of gunk in heater control valve box?under carb ,heater core doesnt seem to be blocked,took most of dash...
im not sure how to remedy the heat problem, make sure the heater core is actually hooked up as many people simply run a bypass. I do know that you need to return the vacuum items because if there is a cable that means it is not vacuum actuated. the gunk may well be radiator or headgasket sealant which unfortunatly causes blockages and buildup in heater cores. i would suggest giving closer inspection to the heater core because everything else you have done is spot on. good luck
Dec 28, 2010 | 1983 Ford Ranger
Getting EEE code on display what does it mean and can it be reset?
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can't find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Sep 24, 2010 | Honeywell Programmable Thermostat Heater
My Honeywell Thermostat has a "-AC" error. Nothing is running (fan, cool, or heat). What does this likely mean?
Go to honeywell.com
If you can’t find what you want, the bottom left and bottom of web
Aug 31, 2010 | Honeywell Electronic Programmable...
I have a Honeywell Chromtherm IV Plus. I put the
HONEYWELL WEBSITE:
Go to honeywell.com
Jan 05, 2010 | Honeywell Programmable Thermostat Heater
I need help programming my home thermostat for heat
HONEYWELL WEBSITE:
Go to honeywell.com
Nov 22, 2009 | Honeywell Programmable Thermostat Heater
Accidentally programming it
HONEYWELL WEBSITE:
Go to honeywell.com
Oct 07, 2009 | Honeywell CT500 Digital Heat / Cool Manual...
2001 JEEP CHEROKEE heater FAN MOTOR RESISTOR LOCATION
passanger side under the glove box but it is always mounted in the heatr and A/C box
Nov 17, 2008 | 2001 Jeep Grand Cherokee
Why can't i get my thermostat to work
HONEYWELL WEBSITE:
Go to honeywell.com
Oct 22, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
THERMOSTAT,P/N CT62B1015,NEED INSTALL INSTRUCTIONS
HONEYWELL WEBSITE:
Go to honeywell.com
Sep 06, 2008 | Honeywell (CT62B1015) Baseboard Heater
GE GSH22SGRSS Side by Side Refrigerator Logo
89 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
